Moles & What They Say About You
melody
9,000 RPM
ipoh
~Moles and what they say about you~
The Chinese Almanac, also known as the Tung Shu, is commonly known as a book of auspicious and inauspicious dates, but there is so much more to the Tung Shu than that. It is a vast mine of information relating to astrology, codes and symbols, derived by the wise sages and philosophers of ancient China . In this issue, we bring to you the secrets from the almanac regarding moles on your face and what they mean depending on which part of your face they appear.
http://img442.imageshack.us/img442/3842/image002fb8.jpg
First, check your face for any moles, and then look at the diagram above to identify the number(s) that are a closest match to the moles on your face. Usually, the moles only hold meaning for you if they are prominent and they are the only one. If your face if full of spots, acne or "little" moles, they do not count. When you've ascertained which position corresponds to the mole on your face, look up the meanings listed by numbers below.
Position 1 to 3
As a child, you are somewhat rebellious and a free spirit. You have an innate creativity and work best when you are given a free hand. Generally, your superiors like your avante garde approach to life. If you have a mole here, you are far better off in business and being your own boss rather than working for somebody. What is promising is that you have the luck to be your own boss.
Position 4
You are an impulsive person, often acting with a flamboyance that gives you charisma and a sparkling personality, but you can be difficult when there are too many opinions. You tend to be rather argumentative, but never to the point of holding grudges. This mole tends to give you an explosive temper and should you decide to remove it, you will find yourself becoming calmer and more at peace with the world.
Position 5
A mole above the eyebrow indicates that there is wealth luck in your life, but you will need to earn it and work harder than most people. All the income you make must be carefully kept as there are people who are jealous of you who might attempt to sweet talk you into parting with your wealth. Be wary of those who try to interest you in get-rich-quick schemes. If you have a mole here, it is advisable not to be too trusting of others. Follow your instincts and be cautious. And never allow other people to control your finances.
Position 6
A mole here indicates intelligence, creativity and skill as an artist. Your artistic talent can bring you wealth, fame and success. It also indicates wealth luck, but this can only be fully realized if you follow your heart rather than stick to conventional means of making a living. Success will come if you are brave.
Position 7
Moles under the eyebrows indicate arguments within the extended family that cause you grief and unhappiness. This will affect your work and livelihood. It is advisable to settle any differences you have with your relatives if you want peace of mind to move ahead.
Position 8
This is not a very good position for a mole. Your financial position will constantly be under strain because of a tendency to overspend. You also have a penchant for gambling. The only thing is you must know when to stop. Meanwhile, someone with a mole here has a tendency to flirt with members of the opposite sex as well as with the same sex. Better be a little discerning where you exert your charms, or you might get into trouble.
Position 9
This mole position suggests sexual and other problems. It is an unfortunate mole and you are well advised to get rid of it. It brings a litany of woes and a parade of problems.
Position 10
A mole here just under the nose indicates excellent descendants luck. You are surrounded by family at all times and will have many children and grandchildren. You have the support of those close to you and will be both materially and emotionally fulfilled.
Position 11
Moles here suggest a tendency to succumb to illness. It is a good idea to have this mole removed especially if it is a large, dark-coloured mole. Otherwise use lots of foundation to cover it.
Position 12
A mole here foretells a successful but also a very balanced life. You are likely to be not just rich, but famous as well. But although you have every opportunity to live the high life, you will have a satisfying home and family life as well. Women with moles here are particularly lucky and tend to be beautiful and glamourous as well.
Position 13
Your children will be a big worry in your life. Your relationship with them is not good. There is nothing much you can do about this except to learn some tolerance.
Position 14
A mole here suggests a vulnerability to food which can be a big problem in your life. You may have allergies against certain foods or you may simply be eating too much.
Position 15
You are a person always on the move and constantly renovating and redesigning your house. You like to be introduced to new things and see new places. You are not happy if you remain in one place for long. You enjoy travel and adventure, and have a very observant eye.
Position 16
You need to be careful when it comes to eating, and also when it comes to your sex life. These are your two biggest problems. You tend to have weight issues which can make you depressed. You enjoy romance, sometimes with more than one person, but because you are a person with some morality, you will feel guilty about it and this will cause you much stress.
Position 17
You will be someone of great social prominence. You are active on the social scene and an excellent conversationalist. There is a tendency to become bigheaded about your success, which could lose you your good name. This will affect you deeply because you draw your confidence and self worth from what others think of you.
Position 18
You are a person always on the move. There is a great deal of overseas travel in your life, but you should take extra care each time you cross the great waters, as your mole prefers you to stay at home.
Position 19
You have money luck and many good friends, so this is a good mole to have. Your weakness is that you tend to succumb to the charms of the opposite sex. In your life, it is this that could get you into hot water, so do cool your ardour!
Position 20
A mole here can be very lucky or very unlucky. If you have a mole here, you are destined either for extreme fame or infamy. You have great flair for creativity and are also highly intelligent, but your talents can be used for both good and bad. You are not a person to be trifled with for you are no pushover and do not forgive and forget easily. This mole is a mark of someone who will go down in history either as a great or as a tyrant.
Position 21
This is a good mole, as it suggests plenty to eat and drink throughout your life. This mole also brings fame and recognition.
Position 22
Your life is always happy and things go smoothly for you. You could well become a sports superstar if you have the passion for it. Moles at the end of eyebrows also suggest a person of authority and power, so if you are the CEO of a company, you will do very well.
Position 23
You have a high IQ, and you are both brain smart and street smart. You have a highly-developed survival instinct and will lead a meaningful and long life. You will be active until a very old age and will have friends and family around you till the very end.
Position 24
You will achieve fame and fortune in your young age and you are advised to use this period to safeguard your old age, as people with moles here tend to have a harderlife as they get older.
Position 25
You will enjoy good prosperity and recognition luck, but do be careful of excesses. Stay traditional in your attitudes and you will have a long and fruitful life.
keke i got a mole on position 12, at the right side....
SG, if none..
means u're safer..
no worries..
hehe..
Goodnite & sweet dreamzzzzz..
melody,
There's some that's missed out. It's for special cases. Check it out.
http://images.fotopic.net/ynndxd.jpg
Moles in position 1, 2, 3, 26 to 31.
If ALL 9 moles are present in these locations, it means you have have special powers. You may or may not know about it yet but yes, you do have special powers. Try to find out what your powers are. Maybe jump off the cliff of a building. You may be able to fly. Or burn/cut/hurt yourself physically, you may be able to heal fully in just a matter of seconds. Or just go rent a pick up truck and kill all the rempits in malaysia, you will never ever be in trouble with the law because somehow, nobody in the world will know you did it and nobody will care about those dead rempits.
If one or more of the moles are missing from those 9 position, you better kill yourself because someone will do so if not you. You will die anyway.
From you chart i got,
Position 21
I do eat a lot. But i don't think it means i have enough to eat everytime. hehehe
Position 17
I am someone. But not one that you can see everywhere. But when i do great things, it does get over my head sometimes. And seek recognition no one can match me. Thats bad.
Position 24
Might be true. when i was young, i have money to spend like crazy. Easy come and go. Nowdays hard to come, but still easy to go!!
Position 15
You will never catch me at home during the day on Saturday and Sundays. I go exploring in the city. Really!! Unless there is a project or job that i have to attend to.
Position 23
This one i dunno la. But i'm working towards it. Anyway i'm sure i don't want to slow down even when i'm old. Unless i'm sick that is.
Anyway its easy if you keep it current. No one can predict the future. Though you can lay down the fundamentals of what happens from what you do now. Sometimes its hard to accept what these face fortune tellers tell you. I have never consulted any before. But one common trait i have observed from these fortune tellers either indian or chinese is that they always tell me (first) that i have something powerful/ special on the lower forehead between my eye. I wonder why la. But they never tell that to my friends. Nowdays if they come i just look away or pretedn that i'm cleaning up my face. hehehe.
i don't consult, too..
could be you possess the 'third eye'..:shades_smile:
