Hi guys..i have many Q here and would like you to share your experience about it..
Now i was using adj abs for my car. i've used tanabe sustec pro and it has taken from DC2 b4. but when i'm using this kind of abs, my car drop too much at rear and when i've adjusted it until max heigth of the adjuster (hi-lo), the clearance between the arc/mudguard and tire about 1 inch.
Actually i want the height clearance between the arch and tire about 2.5 - 3.0 inch so that my rear is higher than front ( kasi jongket kat blakang sket...)....
I've ask my civic fellas b4 and they've said that DC2 absorber is similar with civic and the rear spring is too soft and its only suitable for DC and EG only (i don't know how far the truth of it).
They was advised me to hybrid the front spring of EG6/SR3 to my rear abs and mebi its need a minor modification such as cut the spring until my desire height is achieve. They also advised me to use the stiff and long spring that the original spring of adj. absorber.
My question is;
1. can i use the standard spring of SR3 to my adj. absorber? Perhaps it need to cut kasi pendek...
2. What is the impact and effect if I'm using this standard spring/ lowered spring?
3. Based on your experienced about your car (DA6), what is your advise on me for this matter and what is the suitable spring that you will recommend me to use?
Guyz please help me...i got headache to think all of it
