Isnt is displayed in your odometer?Mileage not sure.. wat i do know the car is 15 years old
Wat i mean is that i forgot the mileage cause i have not yet use the car daily. Still on restorationIsnt is displayed in your odometer?
Mileage plays an important part in gauging whether it's valve seal or piston rings. If piston rings, it's a complete overhaul. If it's just valve seal, you only need to open the engine head.Wat i mean is that i forgot the mileage cause i have not yet use the car daily. Still on restoration
mrmoworkshop.wordpress.com
Thanks bro.. will find out of the cause of it. Any update will be inform. Spark plug already change few weeks ago.![]()
Wira Replace Valve Seal
One Wira come and visit us because of his Wira having white smoke from exhaust usually this issue is engine burning engine oil we decided to do the lowest cost repair job Replace valve seal without…mrmoworkshop.wordpress.com
Here's an example of valve seal replacement without opening the head
Admit it lah. You are hoping for an something to happen. Then got excuse to drop in a GSRT into itmine 20 years at 160k km...
no issue with the rings and valve... touch wood.... choi... choi...
That will be me :p but not exactly hoping for anything lh actually. Just wanna run the engine first bfo any futher mod. Im planning to play NA for my ride..Admit it lah. You are hoping for an something to happen. Then got excuse to drop in a GSRT into it
Uhm .. you have a 1.3 chassis. 1.8 GSRT out of bounds for you. That's why they all hinted at replacing the carThat will be me :p but not exactly hoping for anything lh actually. Just wanna run the engine first bfo any futher mod. Im planning to play NA for my ride..
Like i said.. not planning to change the car nor the engine.. but the block mayb..Uhm .. you have a 1.3 chassis. 1.8 GSRT out of bounds for you. That's why they all hinted at replacing the car
20years and only 160k km?mine 20 years at 160k km...
Thats considered just run-in.
Maybe even the cylinder honing mark is still there...hahahaha.
so big ...very big face
I thought valve seats usually smokes when idling. One of my previous car had that, but normal driving no smoke, only at idling.....Valve seats sorry. Basically incomplete combustion busting out.
Personally I'd fix it. This kinda thing usually means overhaul. Piston rings and valve seats
During high vacuum situations like idle, cold start and engine braking, engine oil gets suck from the cylinder head into the combustion chamber.I thought valve seats usually smokes when idling. One of my previous car had that, but normal driving no smoke, only at idling.....
what do you think will happen... keep things simple. imagine just dumping more fuel in there, whats the expected result... remember just dumping fuel and nothing else into the combustion chamberBtw guys.. is it worth if i were to change my injector to higher cc on stock engine?
larger injectors won't shoot more fuel in la. It's just underutilizing the injectors. Not a great thing eitherwhat do you think will happen... keep things simple. imagine just dumping more fuel in there, whats the expected result... remember just dumping fuel and nothing else into the combustion chamber
