Apm performax abs & spring
A bit more stiff than stock. Ride hide is also a teanie bit higher than stock. Cornering is much more in control. For the price, it's worth it. Cos I can't afford adjustable coilovers.
Normally when replacing new set of spring the height will take few days to settle down. That is if all parts used is intended for the car.
All parts bought were specifically for the Myvi.
APM performax springs and absorbers makes the Myvi too low until cannot clear speed bumps.
That was my first choice. But because it will be lowered, I doubted. So I went ahead with Kayaba RS instead.
I had that setup. Yup, it is lowered and it is not comfortable to ride. The car become very bumpy and everything in the cabin start to rattle.
But the handling improve. Doesn't feel so 'sampan' and take corners better maybe because of wider tyre instead of the standard 175
Mine on RS is also stiff, but still OK. Handling definitely improved. Also because I have the rear antiroll bar. And I'm on 195 55/R15.
Keep to this size, already 2% bigger is diameter, but plenty of tyre choices, cheaper. This is best size for upgrade. If go to 16" and 17", tyres are expensive, less choices and are very bumpy
Thank you for the advice. I'm now on Goodyear. Since this car is mainly for Ipoh town use and sometimes so work, I may move to Apollo for the change. At least save RM80 per tyre.
15" tyres got so much difference? Are you MU supporter?.....hahahaha
Yes! A lot of difference between main stream tyres and economic grade tyres.
I bought these Goodyear for RM250/piece.
The following are the same size from other brands:
Achilles RM125
Apollo RM150
Corsa RM138
I'm not MU supporter. Haha..
Achilles RM125
Apollo RM150
Corsa RM138
What Goodyear model you bought at RM250? The F1D5? Even Michelin PS3 some members getting at RM230 only.
Yup, most economic brand tyres are priced way below RM200.
Because Apollo sponsor MU.....hahahaha
Something with 'Eagle F1' if not mistaken. Dunno la. Maybe Ipoh price higher la.. I just trust the seller.
I know Apollo is the sponsor, they even have MU tyre, which is nuts..
Ah! should be that Eagle F1D5, because the Eagle F1 Asymmetric don't have in 15".....
A thread every 60 seconds
