Discussion On Your Daily Ride
ixeo
4,788
3,080
KL, Malaysia
If lets say lower end model from different brands are being compared together, wouldn't those from more reputable brands fared better like maybe for example, Viking CT5 VS Michelin XM2?
Lower brand higher performance, versus branded lower performance. I choose the lower brand high performance.
Example.. Hankook Ventus V12 evo2 versus Pilot Primacy 3..i take the hankook. price wise, the hankook would be same or cheaper.
RENESIS VIII
7,063
950
Ipoh
Perhaps in outright grip and performance, the lower brand high performance will perform better. But then, how about rubber quality and durability? Will the lower brand have a shorter tyre lifespan and higher wear?
marsha1l_v6
666
130
543
thats your answer. lower brand high performance may have better rubber quality and durability to claim it in UHP category compare to branded low tier tyre.
lifespan and wear, cant expect much if you're using UHP category :driver:
ixeo
4,788
3,080
KL, Malaysia
Tyre lifespan depends on the tread wear of the tyre, BUT it CANNOT be compared across different manufacturers
When Hankook says tyre A is 300 tread wear and tyre B is 180 tread wear, it just means tyre A has longer lifespan, but tread wear ratings between different manufacturers cannot be compared cause they measure it differently.
Only way to gauge is to see real world feedback from owners when comparing.
sweelt
Nov 6, 2016
2,306
248
Bro, sweelt will bo 17" loh.....hhahhahah
That is why need just to shift 1" up to 15".....:driver:
Is not about the brand, but the tyre model. BFG was selling the G-Force Comp T/A, that was performance range but now they bring in Advantage T/A only which is lower end. If you can get G Force Comp T/A by all means use, this one good feedback.:biggrin:
wahh my wira on 17 inch....can feel softest cacing. hahahaha:smokin:
RENESIS VIII
7,063
950
Ipoh
So, the verdict is, one can only really compare after they have used and tried the tyres when it comes to lifespan.
It may not be 100% comparable across different manufacturers BUT it may still give some indication/tendencies. If the difference between TW ratings are not so much, say maybe 20-40 (for example between PS3 at 320 TW vs F1 at 300 TW), then maybe the tires in general might wear out similarly. However if the difference is larger, say 80-100, then more likely the lower TW tire will finish notably faster too (for example between say PS3 with 320 TW vs RE003 with 220 TW). So yes, TW rating might not be 100% comparable between brands but they might still give some useful indicative comparison.
This one no comparison since one cheaper, one more expensive but same category....:driver:
Bro. Renesis, This is the correct comparison like what bro. suprafanatic mentioned, paying less for performance tyres of cheaper brand compared to lower end branded....:driver:
Probably that is why bro. Renesis wants to keep to 14" does not want outright grip and performance......lol:smokin::driver:
RENESIS VIII
7,063
950
Ipoh
So, perhaps in the same category, the expensive one might fare better?
My Wira at the end is still a car that I drive around city for short distances. Outright grip and performance tyres for my next car maybe? :biggrin:
Yup, probably slightly better.
In that case, no need ask us what tyres to use, Just get any entry level tyres that fits your budget......lol:biggrin:
RENESIS VIII
7,063
950
Ipoh
It has been 10 months since I started this thread last year. Just want to give an update on the final decision that I took regarding my earlier questions in this thread.
I decided to take the unused Saga at home and use it as a daily car starting from this year. 10 months had passed since I started using the Saga. A lot of effort and money has been put into this Saga to restore it nicely. I discovered a lot of problems while using this car as daily but thankfully, nothing bad happened to me like having the car died in the middle of the road. Solved all the issues and I can say that the car is now well reliable as a daily car. Though some may argue that it isn't worth the trouble, I'm happy with the outcome of my decision.
ixeo
4,788
3,080
KL, Malaysia
It’s worth the trouble cause it’s cheaper than a new car.
Was it cheaper to do up the saga against the Wira?
RENESIS VIII
7,063
950
Ipoh
It is. Wasn't liking the idea of being tied down by a bank loan for a new car at such a young age where I just started working.
Since I plan to put better quality stuff for the Wira, the costs won't be exactly low to do up the Wira. But the main issue of Wira now is bodywork exterior problem which definitely needed painting as the final step after solving the body issues. I want to get a good paint job for it.
Most importantly, I think the best thing about doing up the Saga is that I can have a backup car that is usable without worry. If lets say I need to leave my Wira for a major repair work for few days at workshop, at least there is still the Saga to cover me and vice versa. Can't deny that having an extra car at home is a good thing during unexpected times. :biggrin: Roadtax + insurance per year is not more than RM400 which I think is not that bad.
I haven't dismantled the front disc brakes before, so I'd just like to ask about this in case anyone's seen a mechanic do it.
The front disc brake has this "plate" behind the rotor, right? The plate's folded edges seem to cover a part of the rotor.
If I wanna change my front discs to 1.6's larger units (additional 1 inch to the overall diameter), it seems that there's not enough clearance between the rotor and this plate's folded edge. Can this plate be adjusted in any way to accomodate a...
