May be delayed because Dec is a busy month for the caterers. :proud:
Heard he needs additional work done, upholstery, seats etc.....
Heard he needs additional work done, upholstery, seats etc.....![]()
He needs to be comfortable while unleashing the power.....
So when is the big unveiling and TT?
Must be frustrating. I know how you feel.Latest update : I'm stressed out over the poor wiring. The crank sensor wire had melted to some degree and the wires were barely touching. This resulted in poor cranking and difficult to start.
it went through some cheap diy wiring ka
Whoever did the conversion either used a half-assed any-how-just-get-it-working mech or was on a super ridiculously cheap budget.
More likely not cheap but still half assed.Whoever did the conversion either used a half-assed any-how-just-get-it-working mech or was on a super ridiculously cheap budget.
Sounds almost like you should have bought a stock one, buy a half cut, and direct the conversion.
I was wondering about these conversion jobs. These engines are quite old. Do the mechanics just take the wiring loom from the half cut and install without inspection? Or do they use those looms as reference and replace all the wires with new ones?
one of the cause wiring melt is not tighten properly. It loose n cause sparks eventually melt n core turn brittle.
Still cheaper to fix the one I have now. I can't afford 20k on an engine conversion and I don't know anyone who can do that with a good wiring setup.
Sigh.. half assed.
Eh. So when you’re coming out with your new old car?
