Lower arm bush
mojo1ne
34
7
1,508
Shd not use hard PU... Like the Ralliart bushes are just reinforced rubber. No absorption will kill the rest of ur lower chassis.
Lan's bush are made in 3 parts, top center bottom. Superpro is molded in single piece if not mistaken. That's y won't break apart unlike Lan's.
Sent from my SM-N9208 using Tapatalk
sanekit
Dec 9, 2015
1,616
157
Those prices we talked about btw are pre-discount. But even then the D2 bushes you found are unbeatable
ya wei. plus if deteriorate, it's cheaper to replace
i thought superpro lower arm bush are 2 parts? if 1 part how to install it? i know the anti-lift kit is 1 chunk of PU but Lan doesnt do that bush. And he doesnt have PU for anti roll bar bush and steering rack bush as well. :burnout:
pac_jb
131
14
anyone tried the besixteen's shop, does bushing too, he's a forumer here,0163514580, heard good reviews , but i never tried, KL area
mADmAN
1,840
547
ive had his soft PU bushings on my rear lower control arm for a good 4-5 years already now. running well... no issues...etc. car was daily driven for about 1-2 years after installing it.. after that, not so daily driven anymore and only comes out once in awhile and for track days. no regrets and definitely recommended.
he doesnt have a shop though. so u may have to remove the parts urself and send to him for the bushings to be done. may take a couple of days.
i got the rest of my car done with pu bushings at Evotec in shah alam as well... again.. few days.. leave the car there etc etc. but this one, though definitely makes a difference in ride and handling quality...i cant say much about durability coz only installed about a year ago and the car rarely goes out now so i am in no position to judge the durability. Main reason i did my other PU bushings with Evotec instead of besixteen is bcoz i was doing other things to the car and figured might as well.
loose_end
3,678
197
Malaysia
Any in P.Jaya, Sunway or Subang area ?
Cheong Mou Kei 4G9XT
580
3,018
Ampang
www.geocities.com
Hi All, Lan Automotive & Engineering do custom PU bushes. From lower arm to engine mounting. Used to have a modded car and the engine mounting tends to show sign of tear every few months, after try out the PU engine mount the problem never came back. Try google it.
Reactions: marsha1l_v6 and Tom
Tom
TIMETOATTACK
Jul 6, 2000
5,566
3,230
This came in good time, I was about to refresh my knowledge on local bush provider for the rear aftermarket ARB on my MINI.
also, long time no see Cheong Mou Kei
marsha1l_v6
666
130
543
Possible to custom fit full rubber instead of PU bushes? :confused:
marsha1l_v6
666
130
543
Yes, that is what is did to my another ex car. It was like 10 years ago. And i remember took out bottom 2 of the engine mounting from my old cefiro and send it to them for solid rubber mount.
Nice..using PU mounting currently...it is solid and nice but it squeaks on bumpy road ..want to see how does full rubber feels like..
btw do u have any experience on full rubber lower arm bush? PU is too harsh for me..
Reactions: alcyon
15,390
LAN A&E last year had a massive fire that burnt down their shop. A friends wira had some issues with their installation and ended up somewhat regretting going to them. I wonder if their workmanship was effected some how.
kurt_629
872
54
johor
mine is not fully but majority are.
initially was hard and noisy but now, i love it..
it's really good investment than the normal rubber bush.
ixeo
4,788
3,080
KL, Malaysia
I wouldn't do it for a daily driver. Immediate regret.
Reactions: alcyon
30,002
Actually, rubber and PU got difference for you? Your ride are on coil overs, right?
ixeo
4,788
3,080
KL, Malaysia
I would. Regret only if you run on bone-breaking coilovers.
Sorry la, I old already, body cannot take it. Now I want magic carpet ride. Best if it came with a driver in the form of a Vellfire.
Reactions: Izso
30,002
Yup, I drove a vellfire before, was better when I was sitting behind.....lol:rofl:
Im driving a 2003 Satria GTi.....and the idling is really unstable...going up and down and most of the time is 500rpm or below...sometimes it even dies when im stepping full clutch...happens whether the air cond is on or off......i went to proton edar service centre........and they said i had to change the throttle body.....they said if the clean it....when they put it back....the car might not start......anyone can shed some light on this problem.....thanks in advance!
