UR rear strut bar
I removed it after using it like for less than a month. Actually I did few modifications on the audio system of the car before moving into handling upgrades. So I had this custom made amp mounting board at the boot. Want to remove the board and the amp, so had to take out this bar. That's when I realised this issue.
no problem as long as all mounting holes fit...
sometimes its due to your parking floor surface not level
Hi sifus,
Need some help here.
Recently I've changed engine kosong (just block and head) from 4G92P to 4G93 SOHC.
Everything else remain stock from 4G92P.
This is originally a Wira 1.6 manual.
Right now I can only hit 300km/38L(about RM80) as compared to easily 500km/38L when it was still using the 4G92P.
New spark plugs were white (too lean) after 1 month.
I tried driving with extreme decency (shift below 3000rpm and cruise at around 80-100km/h only) but still unable to hit past...
