Review: Bosch Engine Oil - Premium X7 5W40
RENESIS VIII
7,063
950
Ipoh
one of my family cars (FD) used to be on only mineral because my folks took the cheapest alternative. when it got to my hand, i was on Castrol FS 5w-40 for 3 intervals before i switched to the current SS 10w-40, twice now already. the difference in the engine's "lightness" is significant, most likely due to the different viscosity. that apart, to me they drain the same cos i keep the oil change frequent:
Mineral - 4000KM
Semi - 7000KM
Fully - 9000KM :driver:
You mean the difference is felt between all 3 types of oil or just from mineral to FS?
RENESIS VIII
7,063
950
Ipoh
the change from mineral to FS had the most significant difference, could feel that the engine was more responsive/lighter upon acceleration. :listen:
Agree. But how about your changes later from FS to SS? Any noticeable drop in performance or same?
RENESIS VIII
7,063
950
Ipoh
on that note, the engine did feel a little heavier at the beginning but i quickly got used to it. from a different standpoint, i prefer thinking that it's torque-ier :biggrin:
If so, I think I should just stick to FS for the next oil change.
RENESIS VIII
7,063
950
Ipoh
goooo for it, feeeel the difference! :burnout:
I did felt a slight difference when I changed from 10W-40 SS to 5W-40 FS while sticking to the same brand, Bardhal. For the next change, I'll probably switch to a different brand and see how that goes.
30,002
Actually, changing between FS and SS won't make much difference is it? One thing I heard about FS is that their oil change interval is longer.
Just because the oil is more expensive people think they can last longer. The oil clean the engine that is why they turn dark. The additives do break down. The only difference between FS and SS and/or Mineral is the oil base. Group 5 FS are Ester base, Group 4 is PAO, Group 3 is hydrocrack crude oil, Group 2 is SS and 1 mineral
---------- Post added at 06:05 PM ---------- 6 hour anti-bump limit - Previous post was at 06:04 PM ----------
You want lighter engine feel can try 5w-30......lol:biggrin:
drummydrew
471
if oil are categorized in this segment, does that mean my practice has been wrong all awhile? should i be keeping the change intervals ~5000KM regardless of FS/SS/M?? :hmmmm:
marsha1l_v6
666
130
543
only thing difference i notice on my decades old engine is no tappet during cold startup and slightly better mileage since i fill up by liter. shell SS 10-40 to molygen 5-40 FS. running it 1k mark..still green color EO.
RENESIS VIII
7,063
950
Ipoh
I din't plan to drag too long for oil change interval. 5000 to 7000km interval will do.
5W-30 I think is not suitable for my engine. I heard now cars like Axia, Bezza uses 0W-20.
30,002
That is the problem, you ask oil company, they ask you follow car manufacturer recommendation......lol:rofl:
To what I know, some prolong especially like conti cars that have 5L or more for engine oil capacity
---------- Post added at 09:22 PM ---------- 6 hour anti-bump limit - Previous post was at 09:19 PM ----------
My VR used to run 5w-50, 10w-60, then 5w-40. I tried 5w-30 but when warm up too noisy then I tried Diesel EO for flush, but when I poured that in my engine, it was much more quiet, so instead of using as flush, I use as my EO. Now running 15w-40 diesel oil but with S rating for petrol, and is so much cheaper RM90 for 7L....:biggrin:
marsha1l_v6
666
130
543
DIesel EO..?care to share? hehehe :itsme:
30,002
Actually have been following some users in other forums for many years already. Most are using Caltex delo 400 and to economize they even buy 18L barrels.
Diesel oil have for diesel engine only and rated C. Latest I think is CI, but I look for those rated for diesel and petrol, means C and S rated. Was at UMW warehouse sale last year saw the diesel oil 15w-40 so initially thought of using as a flush. This oil rated CH and SL and 7L bottle selling around RM80. After I pour that in, my engine was running quieter. My Mitsu hydraulic valve most of the time can hear the tappet clicking away, but with this oil it was way less. So since engine is also old already just carry on using.....:driver:
marsha1l_v6
666
130
543
ooo, i thought you were using diesel as EO. Since you were flushing the engine,my thought were diesel fuel instead of EO.
I guess diesel EO should be ok, have not take a look into it, but hows the engine behave at long distance travel/high temp application?
I did heard there are dragster using cooking oil as EO during drag event. After that revert to normal EO. Engine survive though.:hmmmm:
30,002
Diesel fuel can add a bit to petrol but not to clean engine loh....hhahaha
Diesel EO if rate C only I think better not use...lol
Jac83
164
54
SS EO taking a drag to 12k km mileage and beyond, claimed to be still 'working great'.
https://forum.lowyat.net/topic/4192241
Makes me wonder why my previously used EO Synthetic Blend LM Toptec 4100 5w40 and FS Motul H-Tech 100 plus 5w30 doesn't even last 7k km mileage lol.
Jac83
164
54
Maybe it depends on your type of engine and whether did you use it for track?
Nope no track lol, just city drive, typical na car out there. Using 2gr-fe engine, upon reaching 5k km eo mileage, the buttfeel difference is pretty significant. FC started to deteriorate, engine getting noisier especially cold start and sluggish. Which is why there is no way i can drag on to even 8k km unless i'm being ignorant to the tell tale signs of course haha.
Taking its on-track battle up a notch, Lotus Racing has confirmed the Anglo-Malaysian squad’s long-term success in the highest echelons of global motorsport, with the announcement that the team will soon be starting work on the design and build of a dedicated wind-tunnel facility at its Hingham (UK) base.
In addition, Lotus Racing and Team AirAsia (competing in the 2011 GP2 series) will be expanding...
