sanekit
check isc. I think u playing with the bypass BISS screw to adjust rpm. if 92 have one.
Don play with biss screw. Is for fine tuned, not to set rpm.![]()
Isn't the BISS screw is meant to adjust the idling? You set the idle using the BISS screw and adjust butterly via the throttle adjustment screw behind. ISC cannot adjust right? If rosak need to change the whole thing which gonna cost u around rm300 minimum for brand new ISC unit. :hmmmm:
