issuzark
True also. No problem with fwd actually.Want RWD, then buy and play RWD loh. If not, FWD with power also okay mah!
Nice. What else is done to it?Greeting Guys,
Naaz from Ampang
4G93 SOHC in my persona hehe
just a normal sohc ck, matched with mivec gb
2inch piping and aftermarket muffler
else stock
few idea / planning in mind, wait for the right time and also money to come by in my pocket hahha
Join the gang! Hehehehecan plan to load in Mivec head and wiring man.. become mivec 93..![]()
pistons dont need to be swapped? hmmmm compression ratio might seem alittle off then...
If piston dont change then you get a low comp mivec.pistons dont need to be swapped? hmmmm compression ratio might seem alittle off then...
If you're asking, then yes it isSifu,
wan to ask wira 1.5 SE original extractor 4-2-1 izzit good enough to install in 4g13.
Sent from my SM-G900F using Tapatalk
Can't digest this answer. What if he is not asking...........hhhahhahhahahhahahha![]()
You could try the Toptul 10mm deep socket from Mee Huat
http://www.meehuat.com.my/products/...accessories/14-dr-12pt-deep-sockets-sae-baef/
they are narrow enough for you to unbolt the head
Thanks bro,
one more thing , any cheaper option for measuring the engine head flatness?
instead of using a straighedge, can i use a steel ruler buy from any stationery shop?
i'll give my idea n advise base on what i know so!
i will choose to reply or not...
