There is a problem in your car's wiring bro. i've been in your place as well. I've tried all try and errors but still the same jerking on slow cruising. Suddenly, the culprit is actually a wire touching to the others. Make sure to recheck your wiring bro
I want to put some 25mm wheel spacers on my car. I just know that I could run into issues with rubbing the wheel well. I would like to eventually BONOS kit. I'm guessing this will cause problems if I put in wheel spacers. I currently have the stock 17'' wheels from Honda as well. Is it possible to run a wider tire with spacers? So many factors. Does anyone have knowledge or experience with this? Thanks.
