Ok. VR2 has consulted me. The brake pedals there, reservoir and master cylinder all not leaking.
Just the reservoir flexes.
Reservoir doesn't flex la, that's the firewall and that flexing doesn't cause the pedal to sink all the way in like that. And the problem here only happens when cornering? I really think your master cylinder is a goner. No point repairing it as the repair kit costs a little less than the whole cylinder. Replace the whole cylinder.
for older proton (wira/satria/putra), this problem is usually caused by the hose that connects between the servo body to intake plenum. there are valves (old proton have 2 valve) inside the hose that regulates air into the servo and reserve air pressure in the servo. The first time pedal pressed, the valve(s) may be opening when it should be closed causing air in the servo being pumped into the intake instead of building pressure up from intake into the servo and the first floor triggered the valve to close on second flooring of the brake pedal. not sure if persona hose has 2 or 1 valve.
Note : PLEASE BUY ORIGINAL HOSE. I observed the cheaper 3rd party product is VERY NOT GOOD AND VERY HAZARDOUS (swelling, leak, broken valves...)
That's good advice. But I don't think the Persona has the same setup as the Wira. I don't recall seeing the hose to the plenum. But need stupidcar to check it out.
Strange that it only affects him when in a corner though, if it is the hose then it should affect him in straight lines too.
