Primer needed for small rust removal?
deroll
Feb 24, 2014
46
4
508
Selangor
I need to fix some rust on the underbody. Nothing major and its some small patches around the jack point.
Where can I get the appropriate primer to use for this problem. I went to AceHW and I was told that the primer that they have wasn't appropriate and would not adhere well if used on cars.
Can I just use touch up paint over sanded down rust areas without primer?
ken yeang
6,617
1,327
use the dunlop brand underbody sealant....can be bought at hardware store.
Apply like thick paint. Can be diluted using thinner. Make sure surface is clean before painting.
This sealant is water resistant, withstand road debris, dampens (abit) car under-body noise.
DanzEterna
15,911
3,371
www.primeperdanaclub.com
Ooo ya cvkit's thread right......
hi, i own a L2 kancil but there is engine oil leaks out from blow valve, as i been told is the turbo spoil ady. looking to replace with a L5 turbo.
I heard that those L2 and L5 turbo are quiet easy to breakdown. Are this true??? Please Advise.
And i do heard that some modification need to be done to the turbo, which make the hole bigger for more engine oil to flow in. Does it true???
Hope sifu-sifu here can help.
Thanks a lot
