Lambda Primer Set - Restore ENGINE COMPRESSION
ThunderGod_Cid
SELLER INTRODUCTION
I'm just a regular guy. Being a preventive maintenance guy, I am very selective in additives, engine oil, engine cleaners, and selected performance parts, I am here in this forum equipped with carefully selected and personally tested products to make your car run more efficient, better, smoother and quieter. Let me give your car a magical touch and be rest assured that you will not be unsatisfied, leaving our meetup with your car with a pleasant feeling :D
Trust me.. stay with me throughout the lifetime of your brand new car, it will NEVER, EVER give you problems on your engine. Your car's fuel consumption will not go up, your engine will always be clean. I will also teach you how to keep your engine in tip top condition.
Stay with me throughout the remaining life of your old car, I'll help you to clean things up and restore your engine efficiency, power, and hopefully your fuel consumption and give you certain advise on what's going on in your engine bay ;).
You can look up my blog at Car Preventive Maintenance for more info on me, myself and I.
Cheers
ThunderGod_Cid
Item(s): Lambda Primer Set
Package includes:
1x Lambda Primer - Before Oil Change
1x Lambda Petrol - For Fuel Tank
1x Revo Friction Modifier - For After Oil Change - visit http://forum.lowyat.net/index.php?showtopic=1769383
Price: RM45/bottle each for either Lambda Primer or Lambda Petrol, RM85.00 for two bottles(Lambda Primer and Petrol), RM115.00 for all three(plus revo)
Warranty: n/a
Dealing method: COD, Subang only. Postage add RM15 within S.Malaysia. East Malaysia RM25.00
Location of seller: Subang
Contact method/details: 012-9096996
Age of item: New
Explanation:
Will Type out in detail when free.. lol.
Lambda Oil Primer
- Works as an Engine Flush, but totally different from others.
- Normal flushes are detergent based, and works in a way that the engine actualyl scraps off deposits.
- Deposits then falls off.
- This Causes compression loss when gaps everywhere are no longer filled with deposits.
- So... LAMBDA works not by scrapping, but by MELTING the deposits down.
- So... Whatever small gaps will be filled up and primed, thus, INCREASING COMPRESSION!!!!
- A layer of primer will be coated where there is metal to metal friction.
- Short say, good compression, healthy engine. Dot.
More Reference : http://www.lambda-global.com/oil-primer.htm
How to use : Pour into engine oil BEFORE oil change and drive for 30mins or so. Kindly note that most flushes available in market, when poured in, the car cannot be driven.
________________________________________________________________________________________________________
Lambda Tank Otto aka Lambda Petrol as we call it.
- Also works by melting deposits off the injector walls and fuel system.
- Not only cleans the entire fuel system, but also removes MOISTURE in the system.
- Lubricates the injectors, especially for NGV cars which normally clogs the injectors.
- Beats ultrasonic cleaning as it's hassle free, no need to remove injector and risk damaging o-rings.
More reference : http://www.lambda-global.com/tank-otto.htm
How to use : Pour entire bottle into fuel system aka where you put in petrol... along with full tank for longer cleaning effect.
L
For the time being, kindly visit http://www.lambda-global.com/
What to expect after using these products?
Instant Benefits for Business, Customers & the Environment
By using the lambda Rapid Clean Up System, an engine exhaust emissions test failure can be restored to compliance levels within one hour of failure, without the need to disassemble the engine.
The benefits to the customer, the workshop and the environment are obvious. Examples of the great improvements in engine performance are shown throughout the TUV test results. All vehicles featured were EU exhaust emission test failures, otherwise they were mechanically sound.
lambda products offer so many benefits..
removal of harmful deposits from within your engine
free engine management systems to function within their parameters
restores lost fuel efficiency
restores starting quality
restores smoothness
restores reliability
reduces exhaust emissions
extends engine life
Picture:
http://www.lambda-global.com/images/lambda-pack-shot.jpg
video:
http://www.lambda-global.com/index.htm
Kindly note that this product is accredited by not only TUV(aiyah... now most additive also got), but VAG!!
Reason for sale: For people who meets dead ends on power loss and engine compression loss. Instead of opting for an overhaul, this would just be the solution.
