vibration from 80 to 100 kmh
Nurul771
232
9
Klang
Adoi..I'm also get the same problem la bro..vibration at steering wheel at 60kmh to 80kmh..can someone update the results..maybe bro srh_85m can share ur results. ..tire new. .rim new..perfect balance and allingmennt by bro ah sun autopex. .so what next ?..help me...
Nurul771
232
9
Klang
Got. .everything ok as per discuss earlier in this topic..wheel balance..cone..new tire..rim balance..use machine. .manual check..buy still vibration is the..at anytime its happening. .acceleration time..normal drive. .reaching at 60 to 80kmh..it's start to vibrate..Over than that it will ok..help me bro..headache already la..
srh_85m
Apr 11, 2013
11
Yes i have change and add on some grease onto my drive shaft both sides... now i dun experience vibration on low km/h only on high km/h eg: 150 and above due good year Tyre fuel max assurance... it is useless tyre which not round but an ovule shape.........
4gbanger
1,958
386
1,683
Johor/ShahAlam
i think its not drive shaft bend bro stutz. if driveshaft bend, the faster the worst vibration. but try check la instead..
4gbanger
1,958
386
1,683
Johor/ShahAlam
last time i use nexen tyre also happen.. use for few month, tyre wavy already.. shit
---------- Post added at 07:51 PM ---------- 6 hour anti-bump limit - Previous post was at 07:47 PM ----------
Oh yes, you are right.
one mechanic told me, even if the drive shaft not install back as original position once u open also can generate vibration.. mean, u must mark the original position. then when change cover or bearing, put it back as the original position marked. just want to share.. change my driveshaft cover yesterday.. :banghead:
Nurul771
232
9
Klang
So jame3399..did ur problem solve ? Finally what us the root cause ? Any major part causes that vibration? ..Please share ur final troubleshoot bro..I really piss off with this problem la huhh
Nurul771
232
9
Klang
Any otai could help me. please help la..I'm tired already..problem still remain unsolved..
I have a 1981 Datsun 120Y which very often has trouble starting in cold weather, especially after overnight rain. Even using the choke doesnt seem to work. I'm pretty sure the problem lies somewhere in the carburetor, but my dad suspects the ignition coil isnt making enough voltage for the spark plugs.
But then again I do notice my battery is significantly weaker in colder weather and the cranking isnt as strong. When I give it a jump start the engine would start almost all the...
