Can Wira 1.5 manual cable gearbox change to Clutch Pump??
badguy
i plan to change my cable drive manual gearbox to clutch pump
is it possible to do that??
and roughly how much for that??
thanks alot bro here
y u wanna do that?
long story bro
I change my engine to 4G91 Auto but using back my manual gearbox which is cable
type!
first few month still feel ok but only the clutch is heavier
after check i found the the cable need to bend then only go into firewall (due to the air intake pipe was block the way)
so after few month i found the fire wall was pull in due to heavy clutch cable and i adjusted to cable to maximum already
so now no choice i had to change to pump type or else change car already(hope not to)
so any one can help???
Wanna mod from cable to clutch pump? Can. Pay the mechanic to do it for you. All the mounting points are the same except for the upper clutch pump, the mech will need to drill a hole in the firewall since you came from Auto.
hye, just bought cefiro rb20det, got problem, y my car semput, everytime tarik there alway a lag, sure got lag but this kind od lag when tekan pedal rasa kosong, pls help me
Why don't you create your own thread and ask the "Help me" question there. Don't hijack other peoples thread.
bro...pls create another thread regarding your issue. thanks.
thanks for the reply here
after i survey about the clutch pump
and found that cannot settel the fire wall dent in problem
and the best way is to add a thick steel plate to the fire wall as base for the clutch cable
any one done this before???
can show some photo for me as my house got one Stainless steel plate about 3mm thick x 300mm length x 150mm width
i think is good enough for this
Actually I prefer the cable. Had no problems with them in my former car. Now with my VR and Hyundai, every couple of years have to change the top and bottom pumps.....:mad:
If clutch is heavy change the pressure plate...:biggrin:
U mean this??
https://www.zerotohundred.com/forums/attachments/484862.vB
https://www.zerotohundred.com/forums/attachments/484863.vB
https://www.zerotohundred.com/forums/attachments/484864.vB
@Izso hi ... what if my car ori is manual ... now i just want to add clutch pump, is it plug and play? no need to drill any hole on firewall?
Thanks.
Thanks.
Still need to, because your manual is now cable and need to secure the upper top pump...
i see ... aiks ... is it my firewall still safe after manually drill it ?
how many pump do the clutch pump have ?
recently i press my clutch .. press till leg pain ..
One top pump and one lower pump. Top pump pressure lower pump to work....
If your clutch is heavy, probably your pressure plate needs to be changed.
just change the pressure plate will do ?
roughly how much ? :P
but i guess they will charge more on labour fee, since need to dismantle a lot of stuff in order to change the pressure plate .. =.=''
Yup, Usually pressure plate will go together with clutch plate. One clutch plate wears, pressure plate usually wear and will become heavy too. Since opening up, might as well change both....
No point changing to hydraulic. Once the pumps wears the oil will leak, then need to change pump again...:banghead:
yup the risk of having clutch pump is, it will leak someday and need to service.
but my clutch plate still working fine i guess, because i didnt suffer on shifting 1st gear and reverse gear.
Even though still works fine will be worn, not sure how much only. But if you were to open up to change pressure plate probably replace plate as well, unless it still looks in very good condition...
Write your reply...
