al.montere.7
From Facebook
Is installing an exhaust wrap insulator to your whole exhaust system dangerous?
my ride is turbo charged btw :)
Define dangerous...and why would it be dangerous? Use only thermal wrap that is meant for exhaust then you wont have any dangerous encounter.
cos i read in some forums the thermal wrap increases your exhaust gas... therefor, wearing your headers and gaskets faster
recomended to wrap your exhaust pipings only. if u wrap yr headers there might be
possibility to crack.
Dan, you mean after the extractor?
is it okay if i just wrap the exhaust piping? im just doing this because my undercarriage seems to heat up until the point, that my legs could feel the heat...
Then the problem is more likely heat insulation on the vehicle instead of just the exhaust, no?
if i wrap my exhaust starting from the downpipe to the muffler, and if rainwater touches it, will it have a negative effect?
with or without wrap, (from the downpipe to the muffler) the piping will be wet during rain, esp malaysia style downpour.
make sure the wrapping is evenly done, same thickness, even overlap. Uneven wrapping tend to trap/dissipate heat differently, thus would cause cracks to the exhaust system due to dissimilar heat expansion.
