Zerone Super Thermo Bandage 950
SUPER THERMO BANDAGE 950 was designed, developed & tested over 10 years ago.
Exhaust insulating bandage is an innovative way of retaining heat in your exhaust system, creating more horsepower & reducing under-hood temperatures. Not only maintains exhaust gas heat thru low density but generate a greater exhaust scavenging due lower intake temperature. It is constructed of fiberglass material with 7.5 meter length / 35mm width able to stands 1200F continuous heat up to 2000F peak. It’s also will prolonged the fan motor due to low temperature control.
Zerone Thermo Wrap will not over insulate a system when properly installed due to a proprietary coating that conducts heat across the wrap's surface. This coating control heat build-up and dissipation.
*Note: It is normal to see smoke from the wrap for 1-2 hours on initial usage.
Item: Zerone Super Thermo Bandage 950 (35mmX 7.5m)
Price: RM185
Warranty: 1 year
Dealing method: COD
Location of seller: Damansara, Banting
Contact method/details: 0142222281 ken
Item(s) conditions: NEW
Picture:
***Call or PM me for the best price***
_______________________________________________________________________________
Price: RM185
Warranty: 1 year
Dealing method: COD
Picture:
