Too far la bro. So, you are gonna get progressive spring for front and back from Titan?
Guys, can't make it la. I was delayed because of the accident my gf was involved in. Next time.
The same applies for RCS. But with Titan you probably have to go back to them to have them adjust it a few times before you're finally satisfied. But I guess that's a small price to play for customized suspensions.
Probably true, but then again depends on what you mean by "handling". Do you mean like those supremely stiff suspensions found on GT cars and rally cars? Or for just street handling? No right no wrong la.
But for my opinion, I'd rather go for comfy Koni + Eibach, thick front and rear antiroll bars, a few strut bars etc, solid PU bushings and absorber mounts and comfy not-too-low-profile 195/55/15 tyres or 205/50/16.
Street mah. Performance and comfort compared to the adjustables equivalent. But I concede that the same setup with adjustables would be able to corner more agressively compared to Koni + Eibach.
Bro Izso, any idea where to get koni yellow here in M'sia?
I also headache dunno which to change for my OEM Absorbers...cuz if compare, ori is around RM500+ excluding suspension mounting...GAB SA Series only around RM600+...just RM100 difference...springs not sure wanna change or use back ori..
RM330 for GAB Lowered Springs...
Dude, no matter what brand you go for, as long as you choose an adjustable, you can say bye bye to comfort. And unless your wife is a kaki kereta, expect to kena telinga pulling if you use adjustables in your daily family ride!anyone use SSR ZERONE suspension with hi/low soft/hard..?? is this brand are okay..? in a comfort handling for family man..?
GAB Malaysia doesn't have very good reputation. This is based on what I've read quite a lot of times in forums. I suggest that you consider other brand/options.![]()
If around that price, consider Improve Comfort. Not bad reviews i have heard. More comfort and better handling than stock. But if adjustable and more sportier handling, im still sticking to Titan.
Dude, no matter what brand you go for, as long as you choose an adjustable, you can say bye bye to comfort. And unless your wife is a kaki kereta, expect to kena telinga pulling if you use adjustables in your daily family ride!![]()
thanks guys for your advises..seem like i cant even change my suspension to adjustable for comfort ride..now, i think i want to install with shock absorber which is GAB,Hotbit for my sentra N16 and spring eibach pro-kit..is that ok..?? i heard alot of positive comment on eibach spring seems this spring are 100% from germany,rite..
Inverted monotubes are comfortable meh? Perhaps the cars I've sat on are geared more towards performance. I've been on RCS and Titan cars and I can definitely say they are good, but comfort is gone already la. But then again it depends on your definition of comfort, some have higher tolerance than others. For me, anything that doesn't feel like stock isn't comfort already. Stiffer than stock but reasonably comfortable is probably what best describes Titan and RCS I guess.
