What clutch is good for altezza????
Syamsul Anuar
From Facebook
melaka
i am using toda flywheel...but its not make any changer when i use original altezza clucth...as a new owner of altezza....want opinian from all u guy...
i already use original clucth...can i use trd clucth for more kick....
It is not advisable to use a Toda flywheel with a TRD clutch plate. They might not fit together.
It is better to use a TODA flywheel with a set of TODA clutch and cover plate.
Likewise for the TRD flywheel.
Why don't you use a Toda clutch as well? Shouldn't have a problem with pairing.
Bro! What do you want???? You can use a twin-plate racing clutch also but its just not practical or try metallic race clutch and cover plate and good luck to you in traffic jam!!!
errr what does he mean by more kick??? :confused:
kindly explain. putting in a better racing clutch or better clutch will NOT make your car go faster. only makes ur right foot feels numb n sore on traffic congestions(unless original)
faster way is to put in a 4.7 final drive!!! fuiyo u will get instant acceleration
good luck
good luck
good idea...but how about top speed???
i agree with all of u...maybe use original clucth its better....
of course with such a high final drive, u will definately lose some top speed crusing. but again wat top speed are u talking about? crusing at 180km/h? 200? 220? 240?
stock altezza to reach 180km/h with 4.7 is ok, but probably will stress ur engine n gearbox due to high rpm. 200km also ok...u can try hahahah
so u see, there is NO shortcut, u gain in some area u lose in another area. plus how often u can zoom up to 200 on our normal roads? even highways are packed with cars
unless u put in a 1j/2j then u gain in ALL areas. but its pricey and if the workshop is crappy...ur car is a goner.
good luck
A thread every 60 seconds
