No check light? Possible area:
1) Main Relay KO --> due to bad contact that cause arching then overheated then die
2) EFI fuse blown --> SERIOUS TROUBLE! Need to check for the possible short circuit location of your wiring
3) ECU KO --> due to aging (tua). PM me if you want a long lasting (muda) ECU![]()
Thanks bro...
anyway..have check...the problem is no.2) EFI fuse blown
after put back efi fuse then the check engine is ON :proud: ......BUT.....its no last longer..
when engaged the switch on...efi fuse blown again...try it about 2-3 times...same..efi fuse blown..
is it something wrong with my fuel pump?
---------- Post added at 12:32 AM ---------- 6 hour anti-bump limit - Previous post was at 12:24 AM ----------
emm..i think the prob is the no1 that sifu levin told..bcoz if u take out ECU relay, the light wil off..check this EFI relay first..rite bro levin? just my 2cents..
p/s-klate alik mano gu? kalu nk mitok tlg pomen pm ambo, saing2 rama klate nun..huhu
kelantan at kb bro..ur pomen in what area?wats name?
translate
*klate aloh kb la kito..pomen demo alah mano?namo gapo?
...now..it's time to thank for a good work done by Kit and his crew...Well, I have to...
