got what bro??? u just bought a st171???
Saw a couple of nice pictures of your Corona's, 2Old2Rusty.
I think, I stop looking for changes at my 3A!!
And watching these pictures, I saw something, that leads to the next question:
Your shocks are fixed on the front position of the dome, mine to the back.
'Cause I did not look at that, before my shocks got changed, I have no idea, how it was before.
Also I guess, b/c of not only your 2 cars, I should turn them to the front position.
Even if it is only 1-2 cm, how much does that change, please?
I do not experience strange differences. The car runs straight, the wheel is coming back, so.....?
Nice to get another info.
By the way, a Engine swap, like in your car, how much is that, in Malaysia?? :hmmmm:
most probly ur mechanic put them in the wrong side, but i don't know bout the side effects... well if u think properly, i would assume that 1cm on top the movement at the bottom would be more at the bottom rite, i.e the front tyre would move to the front???
http://www.ozebiz.com.au/racetech/theory/align.html
This is installed in an LE (AE80) but the top mount is identical to the Corona's. On this car the top mount is installed facing the firewall too..
@MCJRC1899
Hihi .. I'm here to answer your question haha ... well, i dont really look at the rev meter when i drive .. just a glance only .. I dont shift gears according to rev meter but I feel my engine instead .. during daytime where the air temperature is hot, I have to shift earlier which is around 2.8k rpm .. at night time where its the optimum temperature for engine to run .. I shift gears at 3.2k rpm ...
For average lah this is my driving style
1st gear ~2nd gear - 2.5k rpm
2nd ~3rd ` 2.8k rpm
3rd~4th gear 3k rpm 4th~5th ? Seldom shift to 5th gear unless driving like uncle or cruising at highspeed, above 110kmph because the throttle response is not so good at this gear
My favorite gear is 4th gear because thats the best haha .. always maintain rev range 3k~3.5k .. when overtake is around 3.8k~4k rpm
Actually, as more I think/read about it, as less I'm worried. 1-2 cm on the top, that will not change the caster to much. Still the strut will be 'behind' the upright position, I think. 'll see that at the weekend.
My guess, it's made for little adjustments between directional stability and handling.
it, and..... changed it back.Update:
I changed the mounting position,it, and..... changed it back.
The changing from the back to the front position made the car a bit more 'nervous', I think (that I could feel that).
Maybe only, b/c I expected it, or simple and easy, because I have only 175- tires on it. Steering is anyway not needing much power, would probably feel different, with 2xx tires.
And it is, till now (today ;-) a car for wet conditions, so a bit more straightforward can't be wrong!
Also I had a smalltalk with a guy from a tire shop. He told me, that the Corona did come with the back position, some decades ago.
Without some other modifications (camber, toe, tires, suspension, maybe engine power, use of the car), he would question the need of it.
That's for now, I'm focused on my carb problem, again.
Thanks
maybe u can check with ragerunner if he hasn't sold his old engine, u can buy his carb cheap from him to try...so when u changed the mounting, u feel that it became worst???:hmmmm: that makes me want to change to ur setup just to try..w
tires (175) and your driving tires (2xx?)
