thankz for ur advice..im going to drive by wire...next week start project...send my car at millennium sunway...
owh you have prob with the wiring.... the check light & engine running in safe mode...
huumm.... for injector just like jo1 said, just measure yr current injector resistance & go buy resistor at electronic store. than put it yr current wiring...
for the ignition coil... cannot use resistor?? i oso dun have experience doing this.... but can try lah.. just measure yr current primary coil resistance & put it in wiring... humm, i don't know if it will generate more heat & fail the resistance.... need to ask electronic engineer first lah before anything bad happen. Or other method is try buy one unit of coil & plug all hole for spark plug wire contact ( secondary coil) .. the coil will act like dump coil... just to cheat the ecu.. dunno it will work or not, can try coz it more safe...
but i think campro use map sensor right... not airflow ....
