Sifu germ has already spoken :D I would say yrv are a good choice but the pricey way ;)
I am sorry...but i have to correct you...
What makes you think the piston bore of a Turbo R is any bigger than...What do you mean by coil?K3 are running on direct ignition....
and all K3 has the DVVT coil...just bukak ur valve cover and see...
Speed cut? japanese governement has the regulations of restricting it...unless the halfcut is obtained out of jap...maybe Russia or singapore....
2 x o2 sensors? normal k3 has it too..even NA....
and think logically...what makes u think DAIHATSU will spend much more money on doing R&D for another base out of K3 but just calling it Turbo R...?
The main difference is the ECU...the fuel mapping in the Management is different...
at most daihatsu will play with compression...just like K3VE and K3VE2...they just raise the compression of the piston and change the ECU mapping...and there you have an engien with slightly higher output.....
---------- Post added at 03:15 PM ---------- 6 hour anti-bump limit - Previous post was at 03:11 PM ----------
Bro, between BOT or K3vet halfcut...i would go for halfcut..and maybe can kahwin with your k3 manual gearbox..
BOT is a fun process...but the tendency of going wrong is high...for a problem free solution...go get a K3vet halfcut..drive it stock...and its problem free..toyota/daihatsu engines are pretty reliable....when stock...
btw...there is another option since u are driving a myvi..get a 3sze....1.5 litre...same engine as alzas....
i would prefer CC...as there is not replacement for displacement.. cheers :rolleyes:
I am one happy owner here...with manual tranny boosting at 0.9 stock boost..
diu , pening2 for that SPecial edition or Type R Edition for wad
Since u say UNLIMITEd Budget:
if want power
1. change Rebore piston
2. LArge intake manifold + throttle
3. high cam + adj pulley
4. exhaust banana
5. standalone / piggyback tuning
6. Clutch Racing 3/4 Puck
7. Cantik punya Amoi .
dun diu them , u tot 1.5 engine easy find a ?
better change internal parts lar
change realistic thing
For the psrts i say , all depends on u
if u unlimited budget can do all of it
but i prefer the Amoi parts . it is FREE lol
then just try plonk a K20A into ur Kenari, get a set of HKS/Greedy/TopFuel turbo kit... boost low low 1.3bar... sure can not only monte bella, but Hawaii Five-O ler.....
Do you know much does an alza half cut cost nowadays?
May i know your WHP ? since you already have experience running on o.9 boost. thanks
agree with Turborized...changing to turbo engine is much more better than BOT...![]()
Im driving myvi yrv now and i would suggest you to get yrv better than BOT-ing your car. like jun_ng_1208 said.
YRV halfcut market price is around 5k - 5.4k only. and dont bother getting the 4wd, you would be wasting your money changing it to 2wd. just a small problem that most myvi yrv problems have is the gearbox would drop, IF you use the triptronic g/b.
Like me i used back my M/T trans back, but theres no more triptronic.
my car stocked dyno 137 hp.
You're using stock clutch plate?
This one I agree, no fun la if using stock clutch. Unless if u plan to play stock forever- It's Fawkes la jun_ng_1208Can use back stock clutch but it recommend to upgrade it as well ;)
This one I agree, no fun la if using stock clutch. Unless if u plan to play stock forever- It's Fawkes la jun_ng_1208![]()
Me only use Trinity on my BOT Myvi. Cannot afford to buy those clutch. Trinity also not bad la....true...potong steam if u boost and clutch slips..keke..
D-sport has a super single...that is oem from OS Giken one...RM bout 3.5k ...hahaha....
yo bro, u dun wanna buy 1 myvi then put K3VET meh..???I put my vote on K3-VET....close eye, no doubt, no question ask....
