exhaust temp?
tks84
128
just want to ask all sifu,
the reason you install exhaust temp is too see the exhaust temp right? but what if
the exhaust temp goes up like hot from the manifold to muffler..not just hot but freaking hot until the cabin inside can feel...
what can be the problem?
A/F ratio? have not check yet
tuning? looks good at 900 rpm
o2 sensor malfunction? don't know
or wrong pipe? 1.6 single cam non vtec head 2 inch after bullet 1.6 inch & muffler sflow
ftzone
full throttle zone
5,339
141
Penang, Prai
www.ftzoneracing.com
Typical exhaust temperature can reach up to 700deg C. under full load or 400-500deg C during cruising. Ignition timing plays a major role in exhaust temperature. Timing too retarded will cause exhaust temperature to rise.
Exhaust Pipes which is restricted also causes temperature to rise above normal.
Lean air fuel ratio.
If you can feel the heat inside the cabin means the vehicle firewall insulation is bad already.
tks84
128
my timing now good liow after tuning..but tell you the cabin when driving (look macho but freaking hot inside!!!!)
Dynamat too expensive lah...plan to do DIY on my own buying the sound proof from acc shop and fix it myself...saw at brothers they are selling at RM 68 a roll...just the sticker not the bitumin..
tks84
128
i heard the Dynamat cost around 1k plus if fix at car bottom,and door side lain harga so if i want to fix the whole car will kena around 1.5 to 2 k correct? better mod engine like this..
tks84
128
haha, true also, better DIY rather than spend so much on dynamat.....i would do it myself too.
watch too much overhauling kot...haha....
bad thing is you like a dunggu sweating and all oily...somemore spend like 2,sometimes 3 or more hours to do... but at the end....:adore:...
might do the heat proof by this week if got chance...but the 2 meter i just bought for sure i wan to fix by this week...:burnout:
With request from bro. Danz, I just post a DIY job I did to connect an additional water tank and pump to get water up to my roof tank.
Short story. I am staying in Old part of PJ and the Mains (water pipes) are pretty old and rusty. A few years a go I had fitted a rocket filter to filter the water as the incoming water was milky and dirty. I still remember when the rocket was fitted the pressure shown was at around 25 to 30psi. As years went by, after a burst pipe some where in the area...
