Yup, seen cut spring before, don't work. I even tried lowering the suspension lower spring support point instead of cutting spring, don't work either. OEM stuff are calculated to work as is, cannot mod them......lolIf TS don mind stiff setup, save the money for coilovers.
Later cut spring not enough height cut again?
Spring rate will be the same if u cut also.
