Wira absorber
If TS don mind stiff setup, save the money for coilovers.
Later cut spring not enough height cut again?
Spring rate will be the same if u cut also.
Yup, seen cut spring before, don't work. I even tried lowering the suspension lower spring support point instead of cutting spring, don't work either. OEM stuff are calculated to work as is, cannot mod them......lol
kaihoong
93
28
Might not consider for cut spring, before already try but no feel as good. Maybe try a sport spring or a used rear hilo bodyshift adj, nowadays many used adj can be find.:biggrin:
lsm1991
1,469
185
just be warned.. used suspension, can be a hit or miss also... god knows what abuse its been through
sweelt
Nov 6, 2016
2,306
248
Thats good decision. Try bro @RENESIS VIII suspension setup.
If you want to get sets of coilovers, see can service or not.
RENESIS VIII
7,063
950
Ipoh
@renesis VII How was your setup, pls share with us.
Eh, I thought I mentioned about it before at the other Wira 1.5 absorber thread?
My setup is ok to me except that the car now looks a lot higher than most Wira out there.
My ex wira, same as most, always had problem with rear suspension. Full load always bottom out, had the rears changed to 25% harder damping and it worked, but then on single to two persons, can feel pretty bumpy......lol
to all sifus here, need help and guidance, i'm on tight budget here, so i thought about two options myself on modifying the exausht pipe. my car is an iswara UK spec 1.5cc 4G15P with injection.
1) should i buy a zenden extractor and pair it up with my existing mid bullet and the rest of the piping remain standard?
2) or should i buy a second hand WISE edition whole piping from extractor to muffler, cut and weld back?
thanks for all the infos shared in advance.
