Saga / Iswara Rear Brake Disc Solution
darahhitam
2,483
5
www.cardomain.com
Vesty! You are still around!
CraZieThug5057
722
man vestax jz wanna herd ur answer about my brake ive posted loooong time ago...
vestax
1,573
7
Damansara Heigh
www.fivio.com
well i hardly login , just that i had subscribe to this thread so i receive and email regarding darahitam's posting , so i had a quick peek on it . crazie i forgot what question la , i`ve not been reading my pm's and also hardly loging into zth already .
CraZieThug5057
722
oiic ok man my question is like this simple here it goes homie..
my ride......wiraSE 1.5 2nd batch fornt disk brake rear drum.....
wats wira 1.5,1.3 normal front disk brake rotor size?....(in inches)
wat about wira 1.6, 1.8 fornt n rear disk brake rotor size?....(in inches)
wat about the mivec rear disk brake rotor size?...how many inches?..
is the wira 16,1,8 rear disk rotor is the same size of mivec rear disk brake?
mivec rear disk brake can fit wira rear brake rite cuz mine is drum....wat about the PCDS is 100 rite?..is GEN2 rear disk brake can fit to wira rear disk brake? if yes how big in the rotor?...
im thinkning of getting either wira 1.8.1.6 or mivec (from chop shop)rear disk brake to be install in my car....n ive seeing a front n rear slotted n cross drilled disk rotor in a performance shops n thinking about buying those cool rotors to b fited in my brake system
but im afarid it conflict the disk rotor lahh coz i afraid that the caliper and knucke/hub will not fit the big rotor thats y i ask default wira front rotor n rear rotor is how many inch n is it any modoifications need to be done to the knuckle or caliper to fit those big inches type of rotors?...
deuscher80
11
excuse me..... i'm new here. i just want 2 ask a few questions. do i have 2 change handbrake cable if i'm using putra rear disc brake? i'm using iswara n 8 hole rims, so it's just like "plug n play la"?
deuscher80
11
:cyclops: excuse me..... i'm new here. i just want 2 ask a few questions. do i have 2 change handbrake cable if i'm using putra rear disc brake? i'm using iswara n 8 hole rims, so it's just like "plug n play la"?
darahhitam
2,483
5
www.cardomain.com
From 4g61t.org
Just to share some info.
Rear Drum ----> Rear disk swap between C10/C13 Colt Hatch and Hyundai Lantra/Elantra.
darahhitam
2,483
5
www.cardomain.com
Another shot. 1994 Hyundai Lantra 1.8 rear disks onto 1987 Colt
Credit goes to "coltturbouk" from 4g61t.org
CraZieThug5057
722
guys my BIG questions havent answered?..wited for it so long?......any ideas u guy can help wiff?
Jun 17, 2006
Prob with my UK spec
I own a Iswara 1.5A UK spec. it's about 10yrs old. 2 yrs back my dad was using the car for a while and he changed the brake pump. Well, since then my brake pedal tends to sink in when I try to stop my car. Plus the car doesn't brake properly now, it takes longer than usual before it hits a stop (even when I floor the break pedal). On some occassions, the brake pedal gets too stiff when i press it.
Is it the servo? Should I change the whole pump set? If it is, how much will a Iswara UK spec model set cost? IT's pretty hard to get it around melaka. Let me know for a second hand pricing on the item too. If you think it's totally something else, fll me in on it too.
cheers mate,
PRAz
qib_akip
286
KL & KUANTAN
ello bro!!! how much selling the rear disc break? with installation? gimme ur best price laaa.... if possible, i need sum 1 to look at my car. cos i've just fit a vr4 into my saga, but its quite hard for me to say. my handling totally lost( jalan macam ketam) easy to say, still under construction laaa, setting xngam laa, etc... anybudy can help? hit me back pls.... tq....
qib_akip
286
KL & KUANTAN
eyyy normally no difference between a u.k spec n local protons. only the engines are... brake prob, change the master pump n surb, hose, bleeding new brake oil, comform ok!!! if still not satisfied, change to a 14 inch vr4 disc brake... comform it will heat the disc!!!
based thru my experience happened to my car...
chinonet77
49
hola... just wondering... where can i find the pin to hold the hand brake cable to the caliper? (can refer image for reference)... so far i tested that it can fit screw size 10... thus need to find one with the same size...
oh yes... any suggestion where I can find chop shop / re-cond / customized bracket to hold the caliper for the rear brake?
Many thanks!
Hello. Its been a while since I've been on here.
Im looking for some suggestions on upgrading my stock suspension system.
I drive a honda eg8 with stock absorbers and springs. I believe that its time for a change as the ride is uncomfortable and the body roll is worrying.
I have installed a front 4 point strut bar and also a rear anti roll bar.
I was thinking of a setup of honda absorbers with aftermarket springs.
My goal is to decrease body roll but not sacrifice too much on...
