Rm8k Wira & Jazz GK5 ownership experience-A long way to go
KHNG940413
668
56
528
johor bahru
change the whole set lor... about RM1k.
already bought the Wira?
Yup,bought the 2nd one. Total is RM8k include insurance,roadtax those blah blah blah.
Have done the service.Everything is still fine. I juz wanna upgrade the brake because of safety & the brake feel really rubbish.Hahahahaha
parakey
1,367
226
663
If you have the chance, go test drive another wira of the same model, to see if it's the same rubbish brakes.
parakey
1,367
226
663
Will do so. Will try and ask my friend does he have any wira in the shop to let me test drive.
This is C97 model so I guess no abs?
If want to check for abs, look at the brake pipes from the servo. See if they lead outwards to the front of the car like mine.
minibeany
598
102
543
I guess it is because you're use to Honda brakes which are quite "makan".
gunnerzz
Jul 3, 2014
2,109
695
713
38
Melaka
Indeed yes. Hahahahahahha.But this wira brake feel juz like my previous myvi.....need to tekan to the end baru makan...hahahhahaa
With drums brake at the rear, it needs to be properly adjustes to get better braking.
The different is night and day.
Yup, agree. Properly adjusted at the drums, many short cut adjust the brake cable.......lol
That's not normal. Wira brakes are generally pretty good in stock form.
- Service the brake servo and change the master pump and stick with ori. Upgrading to Evo pump is fine and all but you'll need to relearn how to brake as the pressure is significantly greater with the Evo one. Some people said it results in "on/off" brakes.
- Any Wira will be damn old so change all the brake lines to steel braided lines. Ori rubber lines will be so soft it expands very easily.
- Change to good brake pads. Avoid pads like metalking as they only bite after they warm up. Cold it's pretty useless.
- Consider upgrading to GSR calipers. The oil channels inside the GSR caliper isn't that much bigger than stock Wira so pedal feel doesn't change much. But the piston is much bigger so you get better bite.
- Upgrade the rears to discs from the Satria GTI or Putra. If you do this get both front and back if you haven't already bought the GSR front. GSR rears need some modification so avoid.
- Use DOT 4 or 5.1 oil.
- Flush your oil system and ensure there's no leak.
  • Like
Reactions: minibeany
The Marketplace Top Posts
Some of the plastic panels in my car have grease stains and other dirt on them. please suggest a product or anything else that that can help me clean these panels. I was thinking about using thinner but i'm afraid it will discolor these panels.
Edit: i also hear there's a place you can go to where they will refurbish your interior for around 200 bucks?
