parakey
1,367
226
You can paint the exterior, but if the joint is at the pillar the interior cannot paint, and rust can come from there.
I did try to save the roof. When I saw small bubbles came out, I had them rectified. My spray painter grind it down to bare metal from the top, paint anti rust, putty, primer and paint. For the interior he remove the roof cloth and scrap out the gum, grind out to bare metal. paint anti rust paint, gum back with different gum, and paint and hook up back the roof cloth lining. It worked for 6 months or so only, then the small bubbles were back. I Intended to keep but since the bubbles came back, sold off.......lol
Not sure how other cars are done but on my mum wira, only the roof panel is replaced. Basically its just a piece of sheet metal thus no cutting and rewelding of the pillar.
lsm1991
1,469
185
depends on which area was cut up. sometimes its cut by the c pillar, that one, xtaulah lazy ke ape, they dont tend to strip everything and paint from the inside
Ah! yours change the top layer only, many they chop and change the whole roof......
You referring to Brake servo, right? Should be double layer, just check whether there is space to go in, but be careful, as without ABS when brakes become too strong it might lock easily.....
KHNG940413
668
56
johor bahru
Sorry to sound stupid. I tot wira doesn't come with abs in 2001.
Ok,noted I will check out for those thing. The braking is really rubbish. Even going 70kmh and you hit the brake but the car feels doesn't want to stop.
parakey
1,367
226
Year 96. ABS goes here. To be fair, very few Wiras had ABS back then
Maybe you can try upgrading the pads first. Try Trestor Advantage pads, they are back in the market.....
sweelt
Nov 6, 2016
2,306
248
Will check them out. My friend bringing a Evo 3 brake pump for me now waiting him to come back. Will try to see does it fit or not.
Check brake oil, bleed. If still soft after 2-3 days, then can decide upgrade evo3 brake servo.
check/change brake pads too. Brake servo wont help if down line not working properly.
Brake MLM ah?....lol
Yah, if some cheap pads, no friction at all....
minibeany
598
102
543
as i know all C97 doesn't has ABS. Only the C99 like Putra, Wira 1.8 and Satria GTi has ABS.
is this ori Wira ABS? or you mod?
Build your own car immobiliser that is simple, cheap and very, very effective.
HTML:
This article was first published in December 1998. Since that time it has proved to be enormously popular. However, many people who like the idea do not have the electronic skills to build it. If you are not familiar with double pole relays and the like, don't try to build this project!
If wiring up a couple of relays doesn't worry you and you can handle a soldering...
