- Apr 18, 2006
- 3,676
- 170
- 1,663
I actually did find a different setup which uses the B18C 87.2mm stroke with custom longer rods using custom raised 19mm wristpin instead of stock 21mm and a single piston ring for ultimate low drag and high power with a rod stroke ratio closer to the B16B!! The most ideal setup but cost MEGA dollar and don't know how many mileage before need to strip to change rings. hehe.. Also those single ring piston dome are scary.. :shcokedcamo: wrong tune and say bye bye to the bottom end
Hmm.. I've never seen a single ring setup before, I'm not sure if it's even possible, as the second ring is necessary for the compression seal, from what I know.. a single ring just can't seal properly. Still, I've always wondered if it were possible. Everyone says it's just not possible, due to the fact that the second ring also keeps the piston skirts from kissing the liners, apart from cylinder sealing.
However, I've seen a forged pistons with nearly the same specs you mentioned, but with dual rings, and the second ring actually sits on the wrist pin hole, due to the higher wrist pin location.. My friend says it's not a very streetable setup, since it's probably going to consume engine oil.
Anyway about those tri-y headers you mentioned.. I remembered I told you about it over a mail or something.. forgot already... but these are the pics.. I stored them in the phone for quite a while already...
These are about 3mm-4mm bigger than the B18C Mugen headers.
Time will tell how much power the B20B (still currently building) when it's finished. I anticipate 290hp+ on engine, could be more depending on intake and TB choices. You might have seen them somewhere, but don't publicize okay?
Owner's keeping his build secret.. for now... esp. from his other friend who already finished his.. :P
Chris, mind pmming me the quotes for a J's racing TB? somewhere from 64mm and up.
Eh, you forgot to mention the intake manifold you're using.. the stock ITR manifold? or ???
I think the stock ones start to be a bottleneck once you hit 250whp, but seems like one guy here already passed that mark with the stock manifold.. (O_o)
I'll be waiting for your results.. the spoon/ssworks block brace price is a bit hard to swallow for me as well. Endyn's a bit reasonable, but it's doesn't differ much from the stock R design.I will be using the B18C 3 CAP type block brace with the ARP Main studs. Should be safe to 9k + rev if wanted too. Hopefully :angel_smile:
