Leaking brake fluid while car is parked outside
shem_lexluger
46
9
Subang Jaya
This is bizarre. Car is AE101 SEG.
I have a leaking brake fluid problem only when the car is parked outside and exposed to heat and rain.
When I parked the car inside the porch hoping to do some diagnosis on the leakage, the brake fluid didn't drop at all for a week.
When it is parked outside, it went from max to min level within approx 3 days, which triggered the handbrake light on the console permanently. Top up the brake fluid and the light will go off. This has happened twice with today being the worst because the level went to below minimum resulting the brake pedal to not engage the brakes at all.
I am not sure if heat is the culprit because when the car is driven I am sure the engine bay is even hotter than the weather outside and there was no loss of fluid. Could it be the rain? At the moment, it's pretty much raining daily for 2-3 hours. :dontknow:
Can anyone give any educated reasoning before I send the car off to the mechs?
Leaking so badly you cannot see the leak in your brake system. Usually will be brake master pump area, and at the 4 wheels. Master pump check outside and inside also, meaning the pedal area....
lsm1991
1,469
185
actually... his description seems weird, outside, it leaks, inside it does not?
sweelt
Nov 6, 2016
2,306
248
663
after drive, touch/feel inner rims by hand. Also all mudguard.
can feel oil stain ? My 2 cent.
But still need to find where it is leaking? Cannot just disappear.....lol:biggrin:
If no visible leak outside, just afraid leaking at master pump and dripping inside under the carpet....
once upon a time, my satria developed slow brake leak at masterpump....
after few years, the day just before i send the car for puspakom due to selling it,
it decide to pee all the brake fluid...
no other way, change to new masterpump cylinder, bleeding the brake, all worked great afterward...
6UE5t
6,756
1,300
I think need someone to press on the brakes and another person then check the system where got leaking. With brake pressure, the leak should be more obvious.
shem_lexluger
46
9
Subang Jaya
Thank you for all your responses.
I have found the leakage area which is at the rear left brake caliper. Managed to find it after prodding around all 4 wheels instead of just looking with flashlight. Then took out the wheel and caliper assembly to see the problem up close. Will be looking for spare parts in the next few days. Any of you guys have experience buying a repair kit? It should come in pairs right?
Still unsure about why the leakage was at its most severe when the car is parked outside but we can forget about it.
Yup, repair kit comes in pairs.....
Perhaps outside, just so happens the brakes engage at a certain angle that it leaks, when inside the dirt/dust shifts so it doesn't?
Anyway, it's just a matter of servicing the caliper? But for it to leak that bad - that's an extreme leak! Can take pics and share?
Probably need to check the piston and caliper's cylinder wall too. Mine got one time, piston rusted badly need to change...:bawling:
shem_lexluger
46
9
Subang Jaya
Hi bro,
Here are a couple of pics of the parts I am planning to replace. Unfortunately I didn't take the whole caliper and cylinder pics as soon as I took it out. Now it has been cleaned so there's no more oil stains visible.
The parts are:
1 rubber ring that the piston inserts into
1 rubber cap to seal the cylinder with an opening for the piston to protrude (this is the leak source)
1 ring clip to secure the cylinder rubber cap in place
Hi guys, would like all the experience modder to advice me regard to this matter.
I actually would like to convert my undercarriage to evo but my mech told me cannot be done ?
I has yet to convert my engine to evo but would like to change my undercarriage first. I waiting for inspection.
