engine oil leaking at distributor.
spyro
33
Hi..
Last few days i,ve removed the distributor due to the engine oil
leaking, according to my friends there's oil seal ( o ring ) is wear off
might cause oil leaking where located inside the rocker or at the distributor
it self. But unfortunately i could'nt find any oil seal except dirt black oil.
Help needed from any toyato taiko, Fyi I'm using 4AGze AE92...
jimmyae101
1,167
112
medan indonesia
yes..change new o ring and apply some sealant on upper and lower cover of engine..because engine oil will in high pressure when hot or running.....yes,i work and drive toyota machine too.staying klang!!!hope my idea can bantu)help)u. :tee:
spyro
33
but my problem is I don't know where,s the o ring location??? is it inside the rocker???
Hanson
83
Brother y dun u try to check whether the engine oil is coming out from the spark plug cable or near engine block there.It's located on the distributor shaft n there's an oil seal inside the distributor but it's quite difficult to replace also..........Hope my info can help.......... :smile:
jimmyae101
1,167
112
medan indonesia
hahaa..check all area engine..distributor,valve cover gasket,timing belt area(warp by balck cover rite)oil sump,flywheel(btw engine and gearbox)block of engine.okie..all is suppect may leaking.u know how to check..just asking..if u dunno..maybe hard to explain to you.TAK FAHAM LANGSUNG if u know nothing about engine.hope can help u.. :smile:
Feilo
780
...Ipoh...
Brother may I ask smthing.... R U really technician from TOYOTA... ???????
Hi! Is it possible to convery Campro engine to use cable throttle? I am using Haltech Sprint 500 ECU.
