taikor...all the screw is plastic wan or the normal steel wan?okokk...thanks...gao dim soundproof already...hahah...hands so tired screwing in and out
got any photo to show us?
hahaha..............wah..dismantle roof ar..nice. so when u want to pass ya knowledge to us ar?
all is steel screw yea........sorry ler...forgot take pic....taikor...all the screw is plastic wan or the normal steel wan?
i have problem to overtake 24 wheels lumber trucks, any better way to increase stock engine?TOHsan now in K3VET virus as well..
taikor....hahaha..............
what i do is
open screw at
1) front passenger and driver sunvisor ( after screw out, the other side is a clip, use something sharp and flat or i recommend 2 flat head screw driver to poke in to the small hole that u can see left and right)
2) then screw out the center car dome light ( got 3 screw, gold color)
3) screw from roof handle at 3 passenger side ( front and rear)
4) screw out 4 bolt nuts seat belt at driver, front passenger, rear passenger side (those nuts are cover by a plastic cover, just take it off very easy
5) tear down those rubber(u know which rubber right?), dismantle the front side panel, center panel and rear panel.
6) pull out 2 plastic clips after u took out left and right center seat belt panel
7) pull out 2 plastic clips after took out rear seat belt panel
8) pull out 3 clips on the roof at rear side
9) knock knock the roof, should be fall down if everything has taken out...hah
yes.....change engine......confirm can overtake them...i have problem to overtake 24 wheels lumber trucks, any better way to increase stock engine?
maybe will be going to Kedah to go for prayer,not sure yet, are u going back to Penang?yes.....change engine......confirm can overtake them...
taikor...this raya u confirm going to PEnang?
