Is it possible to DIY rear disc brakes conversion???
me2kimi
717
276
1,563
Puchong
When I change rear drum to disk few year back, I've noticed interesting method that foreman used to bleed the brake fluid. (He's a senior foreman). While changing the rear disk, he just left the brake hose to bleed by gravity, so that by the time he finish changing the rear disk the hose will be full of fluid. So it can be one man job. No need assistant to pump the brake.
If we remove the camber nut we should realign the camber right? I donno what he did because after I check with alignment machine, there is no need to adjust the camber. Respect la kat foreman tu. Already save RM25 per side for camber alignment.
The Marketplace Top Posts
'(00): Some shots from the recent RCA track day couple of weeks ago, here's a fire breathing S2000 who was putting out great laps driven by Shaun from Ascendant...
