i'm running 16v with blue emanage. its only able to control fuel. means changing the map voltage.
it won't able to control injector, cause 16v running low impedance injector. and can't control ignition as well. toyota running multi tooth, 1 NE 24 wheel cam signal and 1 G 4 wheel crank signal.
i can't remember which signal i use, but once i try to change in emanage, it will screw up every ignition map.
running emange won't able to give you HP. or maybe yes. but that just a number on dyno machine. but will give you a very smooth run.
emanage just helping to maximize your hardware performance.
