getting my acc compressor today,Daihatsu Hc,clean up its...one off simple and easy to find,many model use same like this...pressure at high side 3.53MPa and low side 1.6MPa.not much different than honda denso...but small pulley and no ceramic at clucth...oso light weight... reduce 2.5kg somemore...little2 baru bleh jadi bukit...
Here Tein absorber i want to use,long time at my store...need to polish...give chance to Rex to use its laa...dont know what type tein is this...why must custom??
its for EG/EF..so lighten,without spring..its only 1.8kg...my EG HKS w.out spring 3.5Kg...
And here change for new setup front disk brake...last time use twin port from toyota...need some fancy looking then plan to go for 4pot Nissan.aluminium body....but i still want to maintain disk diameter to 275mm,same like Toyota and Vr4 Rs...CRX caliper screw hole to hole is 150mm,Toyota twin port 141mm,Vr4 Rs 138mm and nissan 110mm.....
Lucky la..Japan spell its with 2 "S" ...if its 'NISAN' dont know laaaa
this is 2 type,red is from rb20 h.cut,silver from rb25 h.cut (dont know what body code)..i can simply polish the rb 25..and i like when the crome turn to yellowish..(i need to try to turn its to bluewish,if S.steel i know how,aluminium i not try yet)...and that red one i can paint it with any colour...dont know which want to use yet..just prepair both.
Toyota disk C.H hole is 54.5mm../Vr4 Rs 68.5mm../Nissan 66mm
Toyota twin port calliper weight is 4.6kg.../VR4 twin port 5.2kg.../ BB? h22a 5.2kg.all without Pad..pad mybe + around 700 gram i think...accept this 2 Nissan with Pad...
Just for preview and compare..Pad
here the way how i measure off set disk..CRX 40mm../ DC? or EG 43mm../ Toyota 2pot 41mm../Vr4Rs 42mm
Nissan 41mm..
P/s-Diameter for inside disk to Hup (or Hup out side diameter) for CRX 139mm../ Vr4Rs 143mm../
Toyota 2pot 130mm (need to machine my crx hub to fit this disk and lose some weight lor)
Last weekend job paint CRX Rim...Ok or kO? this rim is when i get this Rex,its only Taiwan made but i like the petern..who know what ori rim that taiwan copy for?
Playing with balance2 colour left,mixing colour then spry its to under stering rack cover..this its looks..
I still have this old Mugen for standby and need some touch up..have a time try to paint that colour..
