Sooorryy frennn... away from shore... and bz with work.. =)
Airmund bro
sory 4 late reply...where r u fix da SC? mike place? last b4 am leaving, as i can recall, mike
bz install/fix SC into 1 Car...is that u?
risyia bro (look like familiar nickname hihihihi)
4 da 1st time running...yes it was.. bad idling & vibrate...long piping (i gues), bcause, mine fix with FMIC, so air traveling from Filter to the Intake become longer compare to the original setup. Sumore, got leaking, hose/jointer/gasket not properly fix, after careful checking & fix all that things, the result, Yes...the idling still not good but more better compare from the 1st run. After that send 4 tuning my Ultimate at RMD (along & rafi) and end result is OK.. not perfect, but sounds good & smooth... btw am not using ABV
The other result is without FMIC/TMIC (fren of mine) using same SC (SC14), the different is without FMIC/TMIC & short piping, from my observation, they dun have any problem with idling/vibration (because of bad idling, sumtime too-high/too-low can cause engine vibration), just minor, but not so obvious, after tuning, all become good & smooth...
Airmund bro
