zero4 said:HAHAAHAHAHAHHAHAHAHAHAHAHAHAHAHAAHAHAHH
sepat, he answer yes somemore
hahahahha.........cool!zero4 said:is the way u answer questions, no i dun hate anybody here becuz i dun care
little_monster said:option 1 did b4 but not using type-r crank or con rod just B16B 81.25 piston ... the rest all B18C stuff with B16A head and toda cam managed to get 166 whp and torque is around 18.9
option 2 the specs sounds great but the block not done in a proper way the engine would not last
it is obvious yooooSePaT said:the way he put th word after the full stop without space before starting with new sentences reminds me the same way ah tiong did last time.. ngeh ngeh ngeh
chris2000 said:Thanks for all your guys feedbacks.
It seems like alot more need to be done to get a B20B revving high... Hmm.. But we always hear in US guys running 2L and all revving 10k rpm.. If I built a economical B20 and cannot rev above 8500rpm (though most things happen below that due to the torque), I think really no fun le.. Considering Honda Vtec are design to rev high..
So if I go Option 1, will B16B pistons yield too high compression causing detotanation and also make it not reliable? What about valve to piston clearance, do you think its going to be difficult for the mechanic to set??
As for ECU, I know Microtech and Hondata is good, but from my experience, it is how good the tuner is rather than the product. I can't seem to find one ECU tuner i really confident with tuning fully programmable ECU.
Like Hondata I was actually pretty interested in the S300, but just don't know who can tune them properly.
Still confused..
hahahaha... yah yah i am driving a 2L ... but onli 150bhp on flywheel.... ekekke i guess tats good enough for a stock CRV hahahaSePaT said:lemme guess little monster..
u aint on any of the above categories.. so i assumed that more than 220 ponnies now sittin in your engine bay ngeh ngeh ngeh
what is the estimated atw hp for this setup? n the b20 as well...zero4 said:in your case, better opt for:
Option 1
B18CR Block + B16B Pistons + Toda C / Jun Type 3 cams and valvetrain
Rechipped ECU tuned via Greddy Emanage
Everything else stock B18CR
Concerns here is that some said the Compression ratio will be damn high like 13:1 so won't last, some said if Toda C used then ok cause static CR drop. Very Confused.
drop in a microtech LT-10s if u can
