That was my first choice. But because it will be lowered, I doubted. So I went ahead with Kayaba RS instead.APM performax springs and absorbers makes the Myvi too low until cannot clear speed bumps.
As my brother in law says, can go for bigger rims now.. Haha.. But I guess no, the old Myvi will be sluggish..His now is higher, so okay loh......haha
I had that setup. Yup, it is lowered and it is not comfortable to ride. The car become very bumpy and everything in the cabin start to rattle.That was my first choice. But because it will be lowered, I doubted. So I went ahead with Kayaba RS instead.
Keep to this size, already 2% bigger is diameter, but plenty of tyre choices, cheaper. This is best size for upgrade. If go to 16" and 17", tyres are expensive, less choices and are very bumpyMine on RS is also stiff, but still OK. Handling definitely improved. Also because I have the rear antiroll bar. And I'm on 195 55/R15.
Thank you for the advice. I'm now on Goodyear. Since this car is mainly for Ipoh town use and sometimes so work, I may move to Apollo for the change. At least save RM80 per tyre.Keep to this size, already 2% bigger is diameter, but plenty of tyre choices, cheaper. This is best size for upgrade. If go to 16" and 17", tyres are expensive, less choices and are very bumpy
15" tyres got so much difference? Are you MU supporter?.....hahahahaThank you for the advice. I'm now on Goodyear. Since this car is mainly for Ipoh town use and sometimes so work, I may move to Apollo for the change. At least save RM80 per tyre.
Yes! A lot of difference between main stream tyres and economic grade tyres.15" tyres got so much difference? Are you MU supporter?.....hahahaha
What Goodyear model you bought at RM250? The F1D5? Even Michelin PS3 some members getting at RM230 only.Yes! A lot of difference between main stream tyres and economic grade tyres.
I bought these Goodyear for RM250/piece.
The following are the same size from other brands:
Achilles RM125
Apollo RM150
Corsa RM138
I'm not MU supporter. Haha..
Something with 'Eagle F1' if not mistaken. Dunno la. Maybe Ipoh price higher la.. I just trust the seller.What Goodyear model you bought at RM250? The F1D5? Even Michelin PS3 some members getting at RM230 only.
Yup, most economic brand tyres are priced way below RM200.
Because Apollo sponsor MU.....hahahaha
Ah! should be that Eagle F1D5, because the Eagle F1 Asymmetric don't have in 15".....Something with 'Eagle F1' if not mistaken. Dunno la. Maybe Ipoh price higher la.. I just trust the seller.
I know Apollo is the sponsor, they even have MU tyre, which is nuts..
Must be as you said..Ah! should be that Eagle F1D5, because the Eagle F1 Asymmetric don't have in 15".....
you are texting with one of rubber specialist.Must be as you said..
Don't know much about condoms woh......hhahhahahhahahhayou are texting with one of rubber specialist.
