Don't underestimate the Satria Neo CPS .... at 1st i also think like that but once i tried,i pretty impress with it's handling ~how can a fwd car like neo, without LSD somemore can be comparable to alfa 147 in corners? ayam skeptikal:hmmmm:
i've owned a 146 ti, definately theres no timing belt issues since its using timing chain.. later i bought a 155, still a timing chain engine, gives me no problem at all.Well the alfa 147 or 156 are relatively older cars, you might run into wear tear.
The Selespeed is a superb system but you might run into problems that might turn expensive.
So best bought from good owners who know their ride in and out. Italiaauto.net is a great place or Arockv or aroc Malaysia . The key niggles is the timing belt kit that needs replacing 40k kms...cost abt 1.5k. The suspension arm front probably need replacement every 70k kms abt 3k. These are main irritants but fuel pump, variator(cam profile shifter), are considered normal wear tear items.
Honestly for the high performance expectations and pleasure there is a price. If you buy a 2nd hand Selespeed keep 10 k handy in below average buys. But there owners that love their rides and very technical letting go...best only bought from them.
Buuuuuut I disagree with jien on other brands like BMW,Volvo, merc...if you go to the service centers where only they stk parts for newer cars less than 5 yrs in market, it isn't cheap. Things that break won't be like alfas...it will be electronics of the gearbox, abs, turbos, fuel issues air cons etc etc. all brands have their own foibles .that too is from experience.
Advise dabble in things that are within yr means...rest work harder for it.
haha howdo u knowso much? yes its a swaplol..Jien you must have used the 146 Ti for a very short period.
The TS engines are all Timing belts. The 8V 1.8/2.0 were timing chains and last was in 1995..unless you got an engine swap done. All the newer alfas are timing chains again.
Hardcore italian fan...33,147,156...then Dad was with GTV 2000, Berlinas...Just keeping the 156 for now
33 + 147 + 156 + GTV 2000 + Berlina = you are DA MAN33,147,156...then Dad was with GTV 2000, Berlinas...Just keeping the 156 for now
Yep, so true... all brands, it's whether the owners are willing to admit them or not.Things that break won't be like alfas...it will be electronics of the gearbox, abs, turbos, fuel issues air cons etc etc. all brands have their own foibles .that too is from experience.
I would think that ferrari, gtr,porsche etc ain't easy(less effort) to drive. They are probably a handful to drive at the limitWhat I was saying is the neo is good ride, it may not have the panache of a Italian, but its a competent drive, just dont brush it away..I love cars that need to driven to squeeze the performance envelope, the difference being the driver... obviously if you can buy an ALFA, LOTUS,GTR,PORSCHE,FERRARI these are hairy barrel chested drives and need less effort from the driver.
