6 speed!!
[email protected]
40
hi there to all..
my knowledge is not so great about the 6 speed gear box..
i would like to learn more from all the sifu's here..
wat will happen if i just fit in the 6 speed gear box n maintain my stock ecu...
pls do advise..
thanks in advance..
muzhaffar
251
41
i dont think changing 6 speed ecu give major change in car performance since the gearbox is manual..
so, the ecu does not control gearbox too much
unless for the modern gearbox which have traction control etc
almost all components on 6 speed gb is mechanical controller..
so, i think it doesn't give u any prob..
just my opinion
[email protected]
40
bro basically im stuck now as to whether i should get a 6 speed lsd or non lsd..
in your opinion wat would u recommend..
caleb_5375
1,293
14
it depend on wat driving method u usually drive...if drag i wont recommand lsd..if track then LSD..
[email protected]
40
wat r the differences with a lsd gb and a normal gb bro..
im more on track not into drag bro..
how will it effect cornering and handlin..
thanks in advance bro for sharin the info with me..
really appreciate it..
cruiser78
165
10
ENCIK MUZHAFFAR, you're using 6 speed in your AE92? Can u tell me what kind of shifter u use?
muzhaffar
251
41
use 6 speed shifter from the halfcut..
---------- Post added at 05:19 PM ---------- Previous post was at 05:13 PM ----------
not know much about lsd
but what i think, if u use the lsd, it will lock the wheel during accelerating
so, both of the wheel will spin at the same rotational speed.
so, the car will move according to where you steer your wheel..
in contrast, if u use non lsd gb, the wheel with less resistance will tend to spin and the toraue distribution is uneven for both wheel. the wheel rotational speed is not the same, thus it would be more difficult to control the car..
just my opinion...if wrong, dont shoot me
scottwrx
870
24
lsd is mean to ensure that both wheel will spin at the same speed, meaning to say when u are on track, or touge, during hard cornering say left turn, you left wheel will have more grip than the right wheel, if without lsd, more power will be transfered to wheel that has lesser grip, hence wheel spin or power wasted, but if you have lsd, both wheel will spin at the same rate.. and your car can corner with more grip and more power can be transfered to both wheel. this will be very obvious on wet roads..
dustbin
189
just a quick one, sifu Nothin..how many liter of gear oil to use for 6 speed gearbox (C160)? some say 2 liter some say 3 liter...abit of help please...Sifus out there!!
Thanks!!
cybtech
408
6
should be arround 2.5l can put 2l no prob, but thats the min. max 3l,
mine 6speed use whole Motul LSD oil (2l).
dustbin
189
i think i had around 2 over liter of the same Motul LSD oil..thanks
guys i'm sorry for the language..i guess this is what happens when ur car gets broken into....everything gone...i drive a kelisa man...but i have a whole good set of ice...for me 2 listen..why steal?? fuckers...i'm so stress...they broke two of my front windows and took evetrything away...alpine 7998r,prokick mono block,6 channne infinity reference amp, box with kicker cvr woofer...and my spkr...my smart tag..son of a bitch,,,i will get u..pls keep an eye...if u see this stuff pls call...
