4G93T Club
E-Tech
1,115
256
3,183
Johor
Hi all proud owners of GSRs....
Just want to know if many of you are having trouble with ur ecus...
I have repaired some... and gave up on some too......
GSR ecu are numbered 5663 and 7377...
Common trouble are 1. cannot start 2. too much fuel...
I need to know if i should study more in depth to support you guys.
Pls feed back. Thanks...
waikong_loh
186
guys,
can anyone list out the best method to maintain 4G93T engine & performance?...for a newbies like me,it would be a very useful info...;-]...thank you...
my old junk is 4g93t td05 evo3 ecu...
if rajin enuf... check water & engine oil every 2-3days.... make sure tis 2 is @ optimum level.. i preferred fully synthetic oil... and to change engine oil every 5000, semi-synt oil 3000...
my 1¢ advice...
E-Tech - i have no prob with evo ecu with e-manage... but w/o e-manage too much fuel...
ftzone
full throttle zone
5,339
141
3,163
Penang, Prai
www.ftzoneracing.com
guys,
is that true if i'm increasing my boost from 0.5 to 1.0 without adding the fuel regulator can cause the piston to leak?
from where you heard this from? gosh... very misleading statement there.
4G93T engine can be boosted to 1bar without any internal or external modification so whatever provided your turbocharger is still stock (TD04) that is. However, premium grade petrol RON97 is highly recommended if you are boosting at that levels.
e-tech,
5663 ecu common problem cannot start.. because fuel pump relay control easily short circuited.
nowadays alot of GSR going for full standalone like Haltech Sprint 500 as they are affordable.
wailup
186
hie gsrian! long time no posting already. wanna ask sifu2 kalian.. what is the compatible/equivalent for gsr (pcd114) front brake pad and rear brake pad? use waja ones? or wira ones? please advise!
Mrnazmi
510
29
3,028
Drag City
Greetings all GSRians!
Any advice here what brand of racing clutch can be use for GSR Engine? (except Exedy 3 puck)
An additional information such as price, pros and cons, shop to buy and any extra modification to the racing clutch before it can be used will be helpful.
Thank you. :driver:
fadin_remorse
94
4
1,508
Hi bro's which forum can i read up most on 4g93T's? i tried googling but incase..... some help guys....
ylkien
499
KL/PJ
If not mistaken, the front brake pads are similar size to Pajero's.
Best if you take sample to the spare part shop, and the shop will know what fits best.
Jibong
79
hi all,
need help to source some parts for gsr. looking for forged rod and piston 83mm..anybody know where to get it pls let me know...cheers..
ftzone
full throttle zone
5,339
141
3,163
Penang, Prai
Duratech Forged Conrods MYR1500.00
Forged Piston 82mm lo-comp MYR2000.00 (Wiseco or CP)
83mm lo comp rare abit... if got also customised pistons... cost about MYR2400-2500
muskasim
269
Pee Neng
klsim.tripod.com
e-tech,
How much Haltech Sprint 500 ?
Blue>8756
394
may i know if i put gti gearbox into my gsr engine, is it ok?
because i'm currently using 1.5 gearbox and got bearing sound already..
wanted to use gsr gbox but need a lot of modification to install.. summore the cost is higher than using 2 wheel gbox.. compare than gsr gb which is better? for pick up n cruising...
need some opinion from u guys..
wongsengming
79
a 4g93t have not start for 1 yr plus......what to do? change engine oil, gearbox lsd oil, coolant etc? after that only start the engine?
Foreign road block, block only one lane, but typical Malaysian Road Block, Block every lane and squeeze you all into one lane......:banghead::rofl::rofl:
