4G93T Club
Qaramil
35
hahahaaa...at laSt..
---------- Post added at 03:53 PM ---------- 6 hour anti-bump limit - Previous post was at 03:52 PM ----------
me too...heheh...shall we join..
ehhh..mine is 4g93t la...sori looo
Alok
27
miri sarawak
hello, sifu. can the original GSR TD04 turbocharger induction casing be upgrade to bigger side? would it effective?
ftzone
full throttle zone
5,339
141
Penang, Prai
www.ftzoneracing.com
haiyoo... get brand new Walbro la...
ylkien
499
3,018
KL/PJ
Need advice from those who know about fitting Lancer's front body onto Wira.
I have Lancer's hood, fender, lamps, bumper and gril to fit onto a Wira. The problem that I encountered is the gril does NOT fit onto the Wira's body, and thus needs some modification.
What type of modification is needed ?
Besides this, any other modification needed?
ACQ2305
984
184
HeadHunters
heyy guyss,wana ask my first question here..
thinking of changing my engine to a 93T, and was wondering can we use 93 N/A cams on the 93T engine?? is there any difference??? have 2 sets of 93 cams now,so not sure if it comes in handly if i do go turbo.. currently using 91...
Thanks for any relies...
Mrnazmi
510
29
3,028
Drag City
guys,
can anyone list out the best method to maintain 4G93T engine & performance?...for a newbies like me,it would be a very useful info...;-]...thank you...
Most important thing must take care of the engine oil (prefer semi-synthetic oil) make sure it's at optimum level, than all the component will be on good condition, especially the hydraulic lifter (tepet) will not make sound like machine jahit..hehehe. (I refer this for standard 4G93T Standard engine, not upgrade anything)
Check all the turbo host, make sure no liking here and there. If got budget, change it to the stainless steal piping, better flow, not easy to liking, and for sure will not over boost that can make your engine blow.
That's now from me. Hope anyone can top up latter.:driver:
E-Tech
1,115
256
3,183
Johor
Hi all proud owners of GSRs....
Just want to know if many of you are having trouble with ur ecus...
I have repaired some... and gave up on some too......
GSR ecu are numbered 5663 and 7377...
Common trouble are 1. cannot start 2. too much fuel...
I need to know if i should study more in depth to support you guys.
Pls feed back. Thanks...
waikong_loh
186
guys,
my old junk is 4g93t td05 evo3 ecu...
if rajin enuf... check water & engine oil every 2-3days.... make sure tis 2 is @ optimum level.. i preferred fully synthetic oil... and to change engine oil every 5000, semi-synt oil 3000...
my 1¢ advice...
E-Tech - i have no prob with evo ecu with e-manage... but w/o e-manage too much fuel...
ftzone
full throttle zone
5,339
141
Penang, Prai
guys,
is that true if i'm increasing my boost from 0.5 to 1.0 without adding the fuel regulator can cause the piston to leak?
from where you heard this from? gosh... very misleading statement there.
4G93T engine can be boosted to 1bar without any internal or external modification so whatever provided your turbocharger is still stock (TD04) that is. However, premium grade petrol RON97 is highly recommended if you are boosting at that levels.
e-tech,
5663 ecu common problem cannot start.. because fuel pump relay control easily short circuited.
nowadays alot of GSR going for full standalone like Haltech Sprint 500 as they are affordable.
wailup
186
hie gsrian! long time no posting already. wanna ask sifu2 kalian.. what is the compatible/equivalent for gsr (pcd114) front brake pad and rear brake pad? use waja ones? or wira ones? please advise!
Mrnazmi
510
29
3,028
Drag City
Greetings all GSRians!
Any advice here what brand of racing clutch can be use for GSR Engine? (except Exedy 3 puck)
An additional information such as price, pros and cons, shop to buy and any extra modification to the racing clutch before it can be used will be helpful.
Thank you. :driver:
fadin_remorse
94
4
1,508
Hi bro's which forum can i read up most on 4g93T's? i tried googling but incase..... some help guys....
ylkien
499
3,018
KL/PJ
If not mistaken, the front brake pads are similar size to Pajero's.
Best if you take sample to the spare part shop, and the shop will know what fits best.
<p><a href="http://www.zerotohundred.com/?attachment_id=53670" rel="attachment wp-att-53670"><img class="alignnone size-medium wp-image-53670" src="http://www.zerotohundred.com/wp-content/uploads/2013/04/MG_0855-600x400.jpg" alt="" width="600" height="400" /></a></p>
<p>We were at Sepang earlier today for a dual launch of the facelifted MY2013 Gallardo LP560-4, as well as to introduce the new Malaysian team, Team FX Primus Aylezo JH Italia, which will be racing for the Lamborghini Blancpain...
