4G93T Club
jeffy
47
advise needed..
Hi all,
I have the following setup:
4g93T+Mivec top with HKS GT2835 Pro-S turbo. AR.48 on the hotside.
currently running internally gated, with 2.5" Downpipe.
Stock intake manifold and throttlebody, Evo9 intercooler,
Forged internals + ARP studs.
Currently running 4x560cc injectors from evo9, I have another set of 800cc injectors by sard ready to push this baby up.
Most of my friends and workshop are suggesting me to run it with external wastegate for efficiency and stable boost but I'll have to re-do a brand new manifold, and it also defeats the purpose of getting the Pro S version of the HKS2835 as they have another externally gated 2835.
The next thing im going to do would likely be:
1. Alu intake manifold + TB
2. Replace injectors and retune
2.5. downsize current injectors and add 4 more injectors and retune
the Last tune achieved about only 300whp @ 1bar, ran into 3 problems,
unable to hold boost
fuel press drop after 7k
TPS sensor fluctuating.
Right all this 3 problems has been resolved,
What should I do next? This is a daily driven car and im only getting about 6.4-7km/L with light footted driving on my Microtech LT10s. If possible I would want both power and alittle bit more fuel economy, maybe about >7.5km/L I'll be very happy
Would downsizing the injectors and add additional injectors improve on fuel economy for daily driver?
I would hope to bring this up to 1.5-2bar efficiently, can I get some advice from Sifus here?
Regards
Jeff
ftzone
full throttle zone
5,339
141
3,163
Penang, Prai
www.ftzoneracing.com
adding additional injectors before the throttle is a thing of the pass... fuel and air are not mix as good as those that runs with the intake manifold direct to your combustion chamber.
when u already have LT10s you can control the 800cc injectors pretty well. it all depends what your engine fuelling requirements for your target boost. if the current 590cc is not enough to support 2 bar boost.. den you are required to use the 800cc. we have a mivec hybrid using gt35 turbo with 700cc injectors, the injectors maxed out on 1.2bars of boost. so to keep the engine from blowing apart.. we had to limit the boost to only 1bar.
300whp is good enough already for a street car bro... somemore not enough ka? what power target you want?
wailup
186
im going to install e-timer, which require to tap the speed sensor. it said, we need to set the car pulse. so, anybody know wats is the number? 4, 8?? or wat?
contreasjun27
9,000 RPM
9,045
25
subang
haha maybe 400 is only enough for him haha..
ftzone
full throttle zone
5,339
141
3,163
Penang, Prai
stock internals 4g93t with td05 and 1.3bar boost is slightly over the limit edi bro...
danger danger... cannot "tarik" lama lama... piston top land cannot tahan the pressure.
UranusFoo
23
Can GSR RS internal withstand such pressure??? I'm using GSR RS engine with VR4 TD05 turbine, Walbro fuel pump, GSR Banana with external 1.3 bar wastegate & Microtech LT10S management, etc on a LMST Saga.... please advice me ya.... :confused::confused::confused:
contreasjun27
9,000 RPM
9,045
25
subang
agree with that...1bar of boost is more than enough for a longer engine health hehe
---------- Post added at 07:29 PM ---------- 6 hour anti-bump limit - Previous post was at 07:28 PM ----------
not bad setup..
but seriosuly boost too high engine cannot tahan bro...
chrissyong
975
14
the head stud also will out 100%confirm the stock gsr head stud cant hold 1.3 bar with td05,not the piston~is head open make the head gasket blow then the fuel will go where?finally the piston break,this is a blow 15 engine fella answer,i don care ppl trust me or not,i only talk the true~thank you
zeni-tani
49
chrisyong: Hey bro did you recieve my email and PM? Need you to hook me up with that cometic head gasket. Ill buy now, you said you have stock correct?
waikong_loh
186
i have driven with this setting for more than 3yrs...
i believe with good engine management will be fine!
agreed with ftzone.. dont tarik lama lama...
tarik till max 7200rpm is ok... want safe.. tarik till 7000rpm is very safe!
UranusFoo, with microtech shouldnt be a problem to hold 1.3bar.
provided set by pro-tuner.
if u r trust me enuf.. go a head! u will happy with such ''tarik power''!!!
:driver::driver:
---------- Post added at 11:41 PM ---------- 6 hour anti-bump limit - Previous post was at 10:36 PM ----------
i have boost to 1.5bar @ 280ps once.
coz ff, wheel spin badly... my car no lsd
gear 1 - 3 running like a ''snake''!
UranusFoo
23
Bro Chriss Yong, can advise where is the head stud??? is it the teppet??? my teppet noisy like diesel car leh... but me using 1.8mm MMC metal casket lah.... beside that my engine internal is stock GSR RS....
On external for :
1. Fuel management, all changed right from Walbro fuel pump to engine except for fuel injector... with HKS fuel rail, WORKS standard size fuel regulator....
2. For air flow, all changed right from open pot filter (w/o air flow) with S/S I/C piping right up to stock throttle body using EVO3 original intercooler & SSQV BOV....
3. For turbo, I'm using VR4 TD05.... with Greddy Electronic Boost Controller
4. For engine management, I'm using Microtech LT10S.
5. For exhaust, all change using banana with external 1.3 bars AVG wastegate with 2.5" piping right up to Speedworks center bullet & 3" for center to rear Blitz NUR muffer....
6. For GB, I'm using EVO3 1.5 semi-LSD with EVO3 Final Drive & VR4 double pressure clutch cover with Excedy racing clutch pad....
7. For brake systems, I'm using Mit Pajero double layered master pump servo with Skyline R32 front & rear braking systems.... i.e. 4 pot front 2 pot rear... with Pro-RS fuel hose
8. For body enhancement, full Ultra Racing after market bars for Saga LMST except room bar with additional customised bars from UR....
9. Others would be like Pro-Rally plug cable, Arospeed Adjustable cam pulley & Arospeed Aluminium Light weight crank pully, Arospeed Oil Catch Tank, etc....
So bro, with such details if I don't change my internal, with EVO3 TD05 turbine, can I "safely" boost 1.3 to 1.5 bars???
My Microtech is tuned by Millennium Motorsport leh.... but my turbo maximum boost only until 1.1 bars now.... :banghead::banghead::banghead:
My that TD05 fin had been grinded off by 1mm but fully service with new repair kit bcos during half-cut, the fin got pecah2 like kena batu like that....
ftzone
full throttle zone
5,339
141
3,163
Penang, Prai
fuh.. alot of stuffs...
head studs go for ARP Head Studs... i have them in stock. MYR620.00 with postage.
but dun need yet if your engine power do not exceed 300hp
badturz
574
8
WTS JUN 272 Degree Lift 10.85 Hi Cam For 4g93t
With the retainer valve spring.
Reason for sale: Need $$ for other item. Anyone ?
The Marketplace Top Posts
The acceleration is good.. can easily reach 140km/h.... after reaching 140km/h, the car is as if not going to go more than 140km/h... after a long while then can get 150km/h.... it's very sluggish after 140km/h... Any sifus out there can help with this? What is the exact problem? Exhaust Extractor is using ori, mid bullet and back muffler is CF Aerospeed... piping using 2"... Is the the piping prob? What is the correct inner diameter for this 4G93 machine? Fuel regulator also fixed dee....
