Jin,ur foreman really tembak u kao kao....
Not so sure about the extractor size as I bought from R One Racing. Should be 2.3". Exhaust size is 2.3".wats ur extractor size? exhaust size?
what about ur vtec engagement rpm now with the rechip ecu and emanage?
maybe u can share ur dyno chart for hp and torque...
i also using semi syn = motul turbolight 10w40...went for 3 track days(about 80 laps or more) in the past 6 months and the oil level dropped 1cm when checking the dipstick(since the 2 dots on the dipstick is about 2cm)...so mech say its normal..
perhaps changing to open pod can get more top end hp.
nop, almost 90++% wrong only...Jin,
You mean my mechanic is totally wrong?
JIN,nop, almost 90++% wrong only...
not sure, cos see no difren when measure at when cold engine...JIN,
You using fully syn & whack till 8500 rpm kau kau few rounds & your engine oil totally still full when measure?
Wow. Your stock B18CR HP also impressive. Coz on paper 200HP on engine. Normally when on wheel, will need to deduct 15-20% which mean rough estimated for a stock B18C is around 160-170hp on wheel. Correct me if I am wrong...ur friend have any cam or any modified??mine stock b18cr 2000 spec with skunk2 ori intake n 5zigen 4-2-1 extractor n complete 2.3 piping with emanage tuning at jc only 182hp with 18++ torque..... your friend stock can get 190hp n 19kg torque???i must put out my skunk2 intake n my 5zigen extractor ah if want 190hp.........hahahahha:hmmmm:
my skunk2 intake n 5zigen header not work ka????:stupid:Wow. Your stock B18CR HP also impressive. Coz on paper 200HP on engine. Normally when on wheel, will need to deduct 15-20% which mean rough estimated for a stock B18C is around 160-170hp on wheel. Correct me if I am wrong...
This both items can increase 10HP on wheel?my skunk2 intake n 5zigen header not work ka????:stupid:
of coz can...i buy 3 year ago rm1400...super90MM???? <---????s90 trottle body???what is MM???This both items can increase 10HP on wheel?
By the way, your Skunk2 intake how much? Super90MM? Any difference?
i guess....of coz can...i buy 3 year ago rm1400...super90MM???? <---????s90 trottle body???what is MM???
hahhaaa...kasi masuk dalam tank....campur dengan petrol...baru hp naik 100%...hehehei guess....
yellow add 100%, Red aka tap-R can add 200%... ahahhaahahhaaa...kasi masuk dalam tank....campur dengan petrol...baru hp naik 100%...hehehe
hello all from arab world..
last time i post here before 9 months
today i wanna show u something interested
total time in these shots about 22 hours
here you are some
hope you like...
