4G93P Hiccups!
mydvdrom
105
the ignitor is on the right side. let me take a pic and post it but need to wait for me to get back from outstation. if u r in klang valley area, pm me and i can recommend u to the workshop i fixed my fuel and spark probs. they can check one by one for u the causes as they did for mine.
haiyoweiya
46
Good morning mate,
That's great if you can show me the location of the so-called ignitor. And yes, I'm from Klang. Who or which workshop would you recommend fixing this kinda bug?
Thanks~ :burnout:
haiyoweiya
46
did your car's water temperature rise when this hiccup happen?
Good day mate,
Nope it didn't, it stayed steadily all the way. The coolant was flushed last year, using Toyota coolant. Both fans are working perfectly.
Cheers for Monday blues...
:sleep:
mydvdrom
105
here's the pic of the ignitor. sorry not a very good pic. its the black squarish thing below the rusted bracket. there's some cables connected to it. its located standing at the front of ur car on the right of air intake manifold. one end is the air filter and pipings to intake. ignitor is at the other end of that.
haiyoweiya
46
Oooohhh... That black little thingy eh? AFAIK, if this little thingy is broken, you won't get any RPM reading eh? I never know it's called the ignitor. :p
Anyway thanks for the effort! :adore:
Good morning to everyone! :sleep:
mydvdrom
105
mine was faulty and it screwed up the sparks to engine. like it was running on half the cylinders. it did not affect my rpm readings. only that rpm was unstable and dropping here and there.
haiyoweiya
46
Hi mate,
Was the symptom permanently there, regardless of the coolant temperature or distance of travel? It sounded like your problem was all the time there. :hmmmm:
ham_m2
968
20
Klang/KL
www.friendster.com
Good morning mate,
Thanks~ :burnout:
If you are from Klang,I can recommend you to my friend's workshop...
Pm me if you want his workshop address...
last satrurday morning around 1.00am,when i came out from my office for a break,i'm shocked because some"motherfucker" break my glass door driver side just because to take my boost meter(apex'i) and the turbo timer(m's),and this "motherfucker" he just cut the wire and the hose from the boost meter,btw for sure he cannot use my turbo timer because he didn't take the controller because the timer comes with the controller....can u guys imagine i parked my car exactly in front of my...
