ECU Problem...Continue to read...
AD_EG
6,328
231
Ipoh
:rofl: rofl: bro e-tech...that sounds turning on..maybe i should check my "ECU" too :rofl:
E-Tech
1,115
256
3,183
Johor
AD... your still virgin meh?
I think yours kena "rape" oledi- got superchip, changed caps, plug in and out and in and out and in and out and in and out and in and out and in and out and in and out and in and out and in and out and in and out in and out and in and out and in and out and in and out and in and out and in and out and in and out and in and out and in and out in and out and in and out and in and out and in and out and in and out and in and out and in and out and in and out and in and out...where got virgin still...
:biggrin::biggrin::biggrin:
terenceng
37
Bro,
Can i have your contact number? My location is at JB.
I got two apexi power fc in hand now, both got problem, dunno whether can repair or not..
call me if u are intersted to fix it or sms your hp number then i will contact u.
0167363080
Terence.
E-Tech
1,115
256
3,183
Johor
Terence bro....
Me in muar....
If want then post to me with the problem
clearly labelled on da units....
Worst case try to make 2 no good units to
become 1 good unit....
Tq....
Btw...spoilted due to wrong wiring?
Tq
E-Tech
1,115
256
3,183
Johor
Reminder....seen to many of these
already...be safe and check ur ecu....
invicta
532
2
bro.. how to disable auto function in p30 without rechip? and how to remove solder inside hole (on board, 27pin to put socket).. that is default by factory in my p30..
E-Tech
1,115
256
3,183
Johor
Surely by "soldering"....
All this info are available in the net...
iF WANt to DIY.... must go seach and learn like me....
If lazy.... send it to expert...tq
If really want help mail me.... if mood good i take you thru step by step...
ok. Tq
invicta
532
2
ok. Tq
hehehe... last on 2006 i all ready do on my p28, desolder all the tin and rechip..
when i got change to p30 and the external ic is quite into the middle position, it quite hard to desolder..hahaha..
since you already met many type of ecu and facing many prob, so i assume ur expert.. my question is how to disable auto function in p30, beside rechip?
thanks for reply my question..
dcloo
1,784
17
kl
Just replace the RP18 resistor to 1.5k resistor its will work fine
invicta
532
2
i think at jln pasar it quite hard to find 1.5k resistor. how about 1.4k? or higher from that value?
any prob from that value?
dcloo
1,784
17
kl
Quote:
That's is one way to do it....
Btw DC, want help on the Cel 14?
its good if you lend me a hand
E-Tech
1,115
256
3,183
Johor
2 years ago my own car ecu had this trouble...
Never seen 1 with this problem from customer yet.
I suspect could be same cause as mine.... broken copper track .... trace from the iavc ecu pin into the pcb.... look for broken trace....
Worst case send it down to me... (i was the 1 that bought mfactory gear 3rd & 4th from u, sometime back)
---------- Post added at 06:56 AM ---------- 6 hour anti-bump limit - Previous post was at 06:53 AM ----------
Now fro the other way... the way i do it...
Remove- RP17 ( put alot of solder and just push it out)
Jumper- RP18. (000) or just small wire
Done!!! :adore:me?
invicta
532
2
Done!!! :adore:me?
i think for remove rp17 and jump rp18 just only work on p28.. seen a lot this method in us forum. hav u try it on p30?
E-Tech
1,115
256
3,183
Johor
Works on all the ECU I have dun before... P30s....
Up to u.
hey car freaks out there....i'm using a wira yr 2000....actually my mom's car given to me when i entered college in yr 2003...its a auto 1.5.....
i checked out the auto trader where there was an advertisement saying that a guy from cheras wana seel his mivec rs 1.8 engine, the wiring system n the suspension with installation for RM 5500....
i was interested so i went to my regular wiring shop to consult with him....he is a racer...goes to sepang very often n he uses a satria mivec...
