4AF + Blacktop internal part = work?
TRD.AE92
780
40
Since the 4A (Carb) are can interchange the internal part....
So I thinking to upgrade my mum car 4AF (carb) with using the Blacktop internal part (Rod, piston, crankshaft and flywheel set) + Single Webber = worked?
me2kimi
717
276
1,563
Puchong
I also been thinking will 4afe with 4age head either 16valve or 20valve work? what about the output?
TRD.AE92
780
40
4AFE + 4AGE head = worked... But problem is what ECU you going to use?
me2kimi
717
276
1,563
Puchong
stock 4afe ecu not suitable for this setup? let say with 16 valve head, this setup also can't support by stock 4afe ecu?
bernard74
51
Sarikei/Sarawak
Hi guys, my ae101 4afe is going thru an overhaul now, 3rd day oredi... swap the pistons with bluetop 4age 16v. It'll raise the compression ratio from roughly 9.3:1 to 10.3, wonder if can feel the difference or not. Still not sure this swap is safe but I'm willing to try, what do u guys think? Anything else from the GE that can be used in the FE??
EFN
1,294
19
Batu Caves
Why would anyone want to do this? for starters 4AF is an Low Revving economy grade motor and the 4AG (later versions - AE92, AE101 & AE111 20Vs) are all High Comp, High Rev machine. Even if you can interchange the internal parts I doubt it will be really beneficial and cost effective in the long run. Swapping parts between 16V and 20V 4A-G is common but only the most wacky person would want to mix and match 4AF and 4AG.
Like I said, if you can do it without incurring more cost than the price of a total 4AG, then you hit the jackpot...but more likely you will end spending more with follow up tweaks and tuning ;)
pcmoddingmy
1,147
101
www.pcmoddingmy.com
High comp on 4AFE setup (with 4AGE internals or head) might need better fuel delivery system, some sort of management, upgraded oil pump and others parts to support the noticeable gain. End result will be more powerful than stock 4AFE but not as good as stock 4AGE. The engine will definitely not be rev friendly like the 4AGE unless you get the whole 4AGE bottom plonked into the 4AFE... but why not go for 4AGE block afterall? Besides, 4AFE doesn't come equipped with sufficient oil squirters that might cause oil starvation that could lead to quicker wear & tear internally.
If you were to only use 4AGE pistons on 4AFE, the gain might not be much noticeable as going with oversized pistons designed for 4AFE. Also, if you were to use 20V pistons, valve seating and clearance must be checked.... else kiss the valves good bye ;)
Besides, running hi-comp setup requires better fuel... means more expensive to drive around as a daily drive. Even stock 20V are known to knock a little with RON97 in Malaysia! Also, hi-comp setup requires better cooling as well.
Just my 50cent ;)
TRD.AE92
780
40
Hahaha... For me i don't think i will cost over than the total 4AG, another thing is... I just want to make my dad & mum happy a bit with this setup only... They not HP hunger :rofl:
Last time I also thinking to take 7A to mix match, but 7A I currently don't on hand stock...
At moment only 20V BT (engine kosong) have 2 units...
---------- Post added 12-19-2009 at 12:07 AM ---------- 6 hour anti-bump limit - Previous post was 12-18-2009 at 11:56 PM ----------
Yeah... I go with all 4AGE block...
Anyway... 4AF is carburetor engine la, so fuel pump & fuel delivery system is less out the hassle.. only thing is I will use the webber to solve my hassle too
Oversized? If like that I better go for 7A block le...
Valve seating problem only I was concerned, but I still 85% sure it won't hit.
Just my 50cent ;)
webber + setting will solve the above hassle.
scottwrx
870
24
haiyah.. juz get a bt engine with wiring, swap the whole thing in, easier lah... instead spending time on experimenting... bt is 20v, hence the piston is design for 20v only, 4af is 16v, and piston design is not the same, u need to calculate compression, piston n valve clearance etc.... if u plan to put bottom internal to the 4af black, is 20v head n 4af black with 20v bottom, more time consuming...waste more time on tuning n petty matters...
bernard74
51
Sarikei/Sarawak
What about the 4age 16v pistons (AE86) in a 4afe?? same bore 81mm and same stroke 77mm?? both 16v, diff only at the piston head... that was what i was thinking...higher compression...higher hp?? Moreover, same piston skirts and conrod 40mm & 18mm both pressed in....
black910
135
2
TRD.AE92 , I believe you know what you are doing already & you are just getting some feedback to feel safe on your plans. However i feel is a good idea & with a good objective you are trying to move in with all the parts that you currently have ( i mean the BT's) in hand now to minimize the cost. Cheers on your creative ways!!!
P.S - Dump a full set SVT in & all problem solved. **juz my 2 cents**
scottwrx
870
24
bernard, i know that the dimensions are all the same, but i m not really sure of the 4ag 16 pistons, coz need to look at the 4af head to check.. something i have never done, not really familiar with swapping pistons..
TRD.AE92
780
40
The piston head not much different, you can PNP it...
Piston pin for 4AFE is 18mm which is same with blue top 16V too...
higher hp? Yes... because compression ratio are slightly increase.
here are the picture of both piston:
Left are 4AFE and right are 4AGE (blue top)
---------- Post added at 12:15 AM ---------- 6 hour anti-bump limit - Previous post was at 12:05 AM ----------
Thanks for supporting me... and yes you are correct (I just want to double confirm my plan only).
16 valve on 4AFE moded, I don't think it will fall too behind the stock 4AGE 16 valve. Hahaha....
futeball
316
2
www.4aeoc.org
My opinion, if wanna give my mom a pleasure driving, just go fot BT auto.
No need to hassle your brains & sweat for r&d. Just plug-n-play.
TRD.AE92
780
40
hahaha... maybe we are different...
The Marketplace Top Posts
Last time I can get RM 10 - 100 kms, but now RM 30 only 200 kms, RM 50 only 400 kms (last time RM 50 , 500+ kms.
What is the problem? my master pump just replace the seals yesterday, need to drive for 2-3 days again to see whether got leaking or not. Just want to list down the problem. Heard from the mech, the fluid all leaking inside the dunno what 'surbo'? :unsure:
And, early morning I start the engine got like black stain coming out from the exhaust. Engine oil? :blink: , i'm...
